Old 03-28-2009, 03:10 PM
monte55 is on a distinguished road
thread pitch
What would stronger in aluminum.....1/4 x 20 tpi or 1/4 x 28 tpi ?
Nick http://www.nixstuff.com
http://www.youtube.com/watch?v=jTu7wicVCmQ
Old 03-28-2009, 03:24 PM
You might find disagreement of opinion on this one.
I have done tear out tests on 6061 and found that 1/4"-20 is better than 1/4"-28 by quite a bit.
This was with cutting taps not form taps and I have no idea whether the results would be different for form taps.
I also found that if you have a correctly tapped 1/4"-20 thread using a 13/64" tap drill, which gives about 75% thread, 8 threads engaged means that the bolt is almost certain to break rather than the aluminum strip out with a socket head cap screw that is equivalent to Grade 8. Using Grade 5 bolts 6 threads engaged is enough that the bolt will probably fail first.
There is a caution however: If you constantly tighten, loosen and retighten threads in aluminum it will fatigue the thread and this will result in failure in the aluminum.
Need Help!- Thread spec for camera lens filter thread cmays General Metalwork Discussion 3 08-22-2010 02:14 PM
acme thread combos and thread mixing calaber40 Linear and Rotary Motion 5 05-15-2009 09:04 PM
Does anybody make bolts that have the size and thread pitch stamped on the head? squale General Metalwork Discussion 24 11-17-2008 09:37 PM
help cutting 6 pitch thread joe1970 General Metalwork Discussion 10 06-08-2006 09:43 PM
New Ballscrew Pitch? barkster DIY-CNC Router Table Machines 5 12-06-2004 10:02 AM
