I need an 82 degree c-sink but the only ones I find in the books are between 1and 2 inches long we usually use the "zero flute" type with a single hole through the body of the cutter and no pilot Im doing holes that are next to a 3" wall of an aluminum part, and the diameter cant be any more than 3/8" since the holes are so close to the wall |
| This is a link to Rutland Tool. It is a combined drill countersink. The tool is a number 4 1/2 which is a 3/8 diameter shank. The drill part of the tip is 9/64. The angle is 82 degree. I hope this helps. https://www.shoprutlandtool.com/weba...atalogId=10001 |
| McMaster Carr sells them. They are uniflute type C-Sink tip that threads onto a long shank. Almost an exact match to your spec. I thought it was pricey but worked well for me.
![]() OK I got this extension with the 1/2 and 3/8 "general purpose" heads so... how the heck do I run these? I'm drilling a .201 hole, then countersinking it for a #10 screw in aluminum, with coolant (squirt per peck, not flood) I'm running it at 4 IPM and 1250 RPM and the holes look like garbage I'm peck it once, leaving a .015 finish peck this is a LOT slower than I've ever run a countersink the tool is making a large ridge at the top of the hole, the finish looks melted, and I can see the tool wobble as it makes the finish peck the page says these are for steel, brass, and bronze, but I use a c-sink just like the fast-cut single flute all the time the general purpose heads have very shallow flutes and I think the aluminum is packing them up, even at such low feeds any help out there? I still need an extended c-sink for aluminum! I guess Im off to mke my own for now thanks |
| Problem- countersink possible in alphacam? | oakleigh | General CAM Discussion | 5 | 08-21-2009 05:59 PM |
| Long reach milling bits | xcayba | Wood Working Tooling | 1 | 09-01-2008 12:50 AM |
| In one year I will gradeuate with an industrial management degree.WTF is this degree? | KyleH2 | CNCzone Club House | 3 | 06-29-2008 08:30 PM |
| 87 degree countersink | Rainbird | General Metalwork Discussion | 2 | 09-10-2007 02:07 PM |
| countersink 304 stainless | jprobst | Haas Mills | 18 | 06-16-2007 04:20 PM |
