Old 03-24-2009, 01:50 PM
xswilly is on a distinguished road
luer thread for medical
has any one ever turned or milled a luer thread
Old 03-24-2009, 03:55 PM
juergenwt is on a distinguished road
XS- I believe the "Luer" designation is for the taper lock (6%) only. Not for the thread itself. But I could be wrong. Check your print for more info. You could also go here:http://www.beuth.de/cn/J-6533981FB7B...nZWlkPWVu.html
or look for DIN 13090-4. Good luck.
Enter: "Luer Lock" lock or the DIN in the search box.
Old 03-24-2009, 04:52 PM
plastibob is on a distinguished road
its a double start right hand thread. The spec is ANSI/HIMA MD70.1
Old 03-24-2009, 08:55 PM
the blueprint just calls out an iso spec,
which is the 6 degree taper and the thread which is a weird style and also
a double lead
Old 03-25-2009, 09:14 AM
i was looking at thread milling it on a machining center
but the size of the thread mill would be extreamly small
so does anybody know of a source for cutting taps
for a luer thread
Old 03-26-2009, 03:09 PM
XS - The more I look at this the more I believe that "Luer" is for the 6% taper only and the thread can be just about anything, depending on where and how the item is used.
Take a look at this site. It is in German but you will find all types of threads listed for Luer Lock. The German word for Thread is "Gewinde."
http://www.dosiersysteme.ch/produkte...ck_adapter.pdf
You said you had an ISO standard. That would be where you start looking.
Old 03-26-2009, 03:51 PM
petek is on a distinguished road
Looks to be about .1/180 deg (double lead)
.305 o.d.
.257 root diameter
Square thread that is 50% root, 50% thread
I was going to take the same aproach but the tool would need an agressive taper to it because of the .1/180 degree pitch
The measurements are from a plastic fitting
Pete
Old 03-26-2009, 04:24 PM
.305 o.d.
.257 root diameter
Pete
Old 03-27-2009, 03:36 PM
XS - If you want to make it you will need more info. Looks like..... is just not good enough.
Check the print again. If it is in a foreign language you may have to have it translated - no computer translation. What is the ISO designation?
Old 03-27-2009, 03:55 PM
Just trying to help. Measurements are accurate,thread pitch is accurate. Whats your print telling you. That part of the fitting only draws in and releases the taper.
  #11   Ban this user!
Old 03-30-2009, 01:59 PM
Les A W Harris's Avatar
Les A W Harris is on a distinguished road
Luer locking thread details
Pages 7,8,9&10 give thread particlulars.
http://www.wam.go.jp/wamappl/bb13GS40.nsf/0/49256fe9001ac4c749256d2d000e0ab1/$FILE/siryou5-1_4.pdf
Cheers,
Luer Lock Specifications hkmachining Mechanical Calculations/Engineering Design 6 08-10-2010 10:03 AM
Job Opening CNC Operators and Machinists for Medical Device Company in northern New Jersey upperoptions Employment Opportunity 0 12-30-2008 04:39 PM
Medical/Dental machining otisblackwell CNCzone Club House 0 05-14-2008 12:07 PM
Medical CO2 laser tubes for retrofit? wyobmf Laser Engraving & Cutting Machines 2 01-10-2008 08:41 PM
CNC for medical applications mfahad016 General Metal Working Machines 5 10-27-2006 03:49 PM
