Old 03-19-2009, 09:12 PM
rolinger is on a distinguished road
Material and Machining questions
I am using eMachineShop software to help me design my first project. The design is almost done but I need to make certain I am selecting the right material and machining process. However, I lack the knowledge about materials and machining processes as this is the first time I have ever done anything like this.
A. I am making a metal hanger contraption that needs to be very sturdy to hold 20-30lbs of weight. I believe the best material to use is a metal rod of some sort but I don't know material codes. The metal rod diamter/thickness needs to be 0.125" (1/8th inch). Is there a specific code or universal metal codes that are appropriate for what I am looking to use.
B. In addition, I created the design to be made from appoximately one 24" metal rod, bent in a variety of ways, eventually creating a full loop so the end points can be welded together. What is the best machine process to do this using the above metal rod?
I attached a photo of a hanger that I believe is similar to what I need in terms of material. This is labeled as a "polished brass and it is the thickness and sturdiness I need. This product is also similar in nature to what I am trying to do....one piece rod, bent in a variety of ways, creates a full loop with end points welded together.
Thank you.
Old 03-19-2009, 10:57 PM
underdog is on a distinguished road
Hi. Welcome to metalworking. You'll have fun.
Bendable metal is not my thing, but if you call a local steel supplier (yellowpages) and ask for a very ductile ("duck-till") metal, they can direct you. Also a local sheet metal shop may help you if you buy the rod there from them with cash. (ductile means bendable without breaking). Steels generally have a four digit number. The numbers indicate something about the properties of the steel.
Hoss 4th axis material list questions seanreit Benchtop Machines 11 04-14-2008 06:20 PM
Questions on Machining Building kinetic_arts General Metal Working Machines 0 11-10-2007 11:32 AM
on Gildemeister speed 12 -7 hard material machining Ashu Hard and High Speed Machining 0 10-16-2006 08:14 AM
Machining TZM material, anyone? home-tek General Material Machining Solutions 2 01-16-2006 09:04 PM
Lathe machining questions devinchi General Metal Working Machines 5 02-25-2004 11:17 AM
