Old 03-14-2009, 02:55 PM
jmcglynn is on a distinguished road
Plunge Roughing - speeds/feeds guidance
I have a small part I'm making, it's about .75" x 2" outside, 1018 steel.
I'm currently using a pocketing operation on the inside area -- the part in blue in the screenshot. With a .1875" 4 flute carbide EM, .015 DOC and 30 ipm it's taking like 15 minutes to clean this out. The interior is .537" by about 1.5 and I need to go .5" deep.
Waaaay too long for this part.
I'm going to try plunge roughing to speed this up, using a .5" carbide NC counterbore (essentially a flat bottom drill, no pilot).
Any recommendations on depth of cut, rpm and feed (plunge)?
At 400sfpm and .00275 CPT I get 3055 RPM at 33 IPM. Assuming a pecking operation at a .1 DOC, this would be under a minute to rough it, and maybe another 2 minutes to clean up the walls. Much better.
Anyone have some experience with this?
Old 03-14-2009, 03:07 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
why are you only taking a .015 depth of cut ?
could you not ramp in a .5 endmill with a .025 to .05 ramp then come in with a finish endmill to clean up the rest , it would be much quicker than plunging
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 03-14-2009, 03:17 PM
masonbcaldwell4's Avatar
masonbcaldwell4 is on a distinguished road
Drill a hole down through, then use a .5" coated roughing mill to take the whole DOC in one, running about 200-300 rpm and 0.7 ipm feed. just keep it flooded.
Old 03-14-2009, 07:40 PM
Oh, totally. I ran the initial parts this way to verify the design with the cutters I had on hand, now I'm looking for the fastest way to get the job done so I can blast out a bunch of these.
What I've read so far leads me to believe that plunge roughing will be faster than ramping in by a bunch. I could be wrong, that is why I'm asking.
At the same feed rate with a 7 degree ramp in the operation is about 50% longer than plunging, but I'm guessing on feed rates for plunge roughing right now, so that may not mean anything. Either approach is considerably faster than cutting the whole thing out with a 3/16 cutter
Old 03-14-2009, 07:53 PM
dertsap's Avatar
Gold Member
i believe that plunge milling is a good way to remove materials in large parts with hard to machine material but if you calculate a .5 endmill ramping .05 dp at 20 -30 ipm with a distance of 1" ,how long will it take ?
Old 03-14-2009, 08:02 PM
Ramping, 7 degrees, .050 doc, 30 ipm = 110 seconds
Plunging, .1 doc (pecking), 30 ipm = 53 seconds
Like I said, both are way better than 15 minutes (plus ~ 3 minutes to clean it up and get into the small spots.
I'll try it both ways and see how it works out in practice. I've got about 100 of these to make, so a minute matters.
Old 03-15-2009, 01:40 AM
dertsap's Avatar
Gold Member
it would only be 22 seconds
with a .05 depth of cut you would need to take 11 passes 30ipm = 2sec/inch
i wouldn't push it quite so quick with a standard carbide
Problem- Does the v23 demo have Plunge Roughing? moldmker BobCad-Cam 3 02-18-2009 02:01 PM
Need Help!- 2 speeds plunge feed? Claude Boudreau BobCad-Cam 4 05-08-2008 04:48 PM
plunge roughing techniques? championp Surfcam 11 02-05-2007 06:11 PM
Plunge roughing? RdHawg Hypermill 3 01-03-2007 05:42 PM
plunge roughing pockets daw General Metal Working Machines 1 10-29-2003 05:04 AM
