Old 03-14-2009, 12:18 PM
wrechin2 is on a distinguished road
Boring head help!!
I am boring out cylinders on a outboard block. Have no problem centering and all that. My question is what RPM's can I run my boring head at??? I am running at 270 rpm with a .003 feed rate. finish is good plus I have to hone to finish. Problem is it is SLOW GO! What rpm should I run this head at? I have enclosed a pic of the boring bar I have, not actual but the same. R-8 spindle on a bridgeport machine with the off set tool. Thanks to all who reply!!!
Old 03-18-2009, 11:18 AM
roysol is on a distinguished road
Stay where you're at.
Given the P.O.S. criterion style boring head with a large offset boring bar (held on by one screw), and an r8 interface and likely not the tightest spindle bearings (quill, if you prefer), I think you've done well.
You said "cylinders", plural. If you actually have some production quantity to do, I would be looking at a different machine and tooling. The imbalance of that boring head alone will severly limit your rpm. Feed rate is a function of rigidity and tool nose radius. You can feed faster with a larger radius, but the increased contact area may cause chatter.
Cheers!
Roy Solomon
Old 03-18-2009, 11:51 AM
no chatter what so ever. Roundness is under .0005. I was impressed, just very slow process. End result is good. I sped up to 650 rpms at .0015 feed rate and it was ok. Alot faster and still good finish. Thanks for the info!!!
Boring Head artin51 General Metalwork Discussion 22 07-10-2008 05:12 PM
Chandler Duplex Boring Head glmoore General Metal Working Machines 5 05-30-2008 09:32 AM
What Boring head should I go with for CNC? SchurrPower General Metalwork Discussion 4 03-10-2008 05:07 PM
Making a boring head rigo430 Metal Working Tooling 6 09-20-2007 10:08 AM
What size boring head should I buy? Kevin Harpham Metal Working Tooling 2 02-09-2007 04:55 PM
