Old 03-12-2009, 11:32 AM
jimlh is on a distinguished road
Drillpress for 23mm smooth flat circular face bore?
Greetings,
Let me start by apologizing if this is the wrong place to post things like this, if any moderators see this please feel free to move it. I also must apologize for my lack of experience regarding this.
My problem:
I am trying to fabricate a fitting to mate with an existing piece that has 18mm x 1.5mm male threads with an o-ring. In order to accomodate the o-ring it looks like I need a 23mm diameter circular smooth flat face around the female fitting around 1.5mm deep. Is there a good way to do this using a benchtop drill press? I cannot seem to find 23mm end mills, cutting burs or any other thing that seems like I could use for it. The material I would like to use is bronze or brass.
Thanks in advance for any suggestions.
Jim
UPDATE: Ok Im assuming by the lack of replies that this question falls below the threshold of worth answering, fair enough. I am pretty sure the real way to do this is to use the most basic of procedures with a lathe, or interpolation with an end mill. But I do not have access to a lathe or milling machine, only a drill press. While I am planning to someday have a cnc milling machine and a lathe, I certainly can't afford it for this one cut. I am hoping that some machining allstar would toss out a cool trick from their bag of experience or at least mention why I shouldn't even be going down this road.
Last edited by jimlh; 03-12-2009 at 02:51 PM. Reason: Unspecific title, Updated to elicit some response
Old 03-13-2009, 12:19 PM
jimlh, you might want to check out hydraulic porting tool suppliers or catalogs. There might be a commercially available tool.
As far as circular interpolating with an end mill, I had bad luck there. The little circular swirls in the finish propagated leaks. These were very high pressure valve bodies.
Dick Z
DZASTR
Old 05-30-2009, 11:53 AM
handlewanker is on a distinguished road
Hi Jimlh, what you need for a drill press is a spot facing cutter.
This is just a round bar like a boring bar that is held in the drill chuck, and has a round or square hole through the side about 1/2" up from the end.
Then you make a flat faced tool bit from a piece of High Speed Steel, that sticks out the side far enough to sweep the diam of the face you're going to cut.
The 1/2" diam end, or whatever diam you have in the bore, end length, fits into the bore and acts as a steadying guide when cutting the face.
More details with a sketch if you desperately need it.
Ian.
Old 05-30-2009, 09:18 PM
PixMan is on a distinguished road
You might be able to get a forum member to help you out. Where are you located? I've got a lathe and a manual mill (with a rotary table) and would be willing to help you out with this if you're near central Massachusetts.
Torchmate 3 small shop machine no pierce problem PHSS Torchmate 6 11-26-2008 08:18 PM
Hi and a small problem davegt27 Haas Mills 5 07-03-2008 09:57 PM
new machine M70 controller small problem Beaker Mazak, Mitsubishi, Mazatrol 4 01-20-2008 01:01 AM
Looking for ideas for a small mill DXF files needed Fixittt Benchtop Machines 0 08-21-2007 12:21 PM
Speed problem when routing a lot of small lines. Witsenburg Mach Mill 18 06-30-2007 02:19 PM
