Old 12-25-2004, 06:44 PM
OCNC is on a distinguished road
What are these tools used for?
My nephew recently came into posession of some vintage machinist tools. Among them were the two pictured below. Does anyone know what they're used for? The upper one is by Starrett and the lower by Craftsman. Rotating the shaft on the right causes the dial to rotate. The rubber cone on the tip of the Craftsman suggests that it was intended to be pressed into the center of a shaft. The Starrett may be incomplete as it lacks a similar cone. The end of it's shaft is hollow.
Chris
Old 12-25-2004, 06:48 PM
gmfoster is on a distinguished road
They are Tachometers. Uses for measuring speed of things.. You count the turns in a given amount of time... Can also be used for linear speed.. Have to be used in conjunction with a known time frame and a little math..
Old 12-25-2004, 08:31 PM
scott m's Avatar
scott m is on a distinguished road
ocnc, gmfoster is 100 % correct they are rpm indicators and I would add that you insert the point of it into a hole (center drill or otherwise) to take the rpm (or is it feet per minute? may need conversion) reading of a shaft or similar part. They often come with rubber wheels of different sizes and for different applications. You hold the rubber wheel against a pulley or what have you and as it spins you watch your clock or watch. Watch it . Scott.
Tools advice needed for start pigifly General Metal Working Machines 5 12-10-2009 03:18 PM
Using layers to pick tools dozer CNC Machining Centers 5 03-06-2005 06:53 PM
shopbot tools with gecko 340 najnielkp Gecko Drives 5 02-21-2005 07:15 AM
Anyone tried the 2D geometry tools? S4 Monster SprutCAM 0 02-02-2004 01:09 PM
