Old 02-26-2009, 09:55 AM
JWB_Machining's Avatar
JWB_Machining is on a distinguished road
Clamping Threaded Rod?
Hey,
I have a piece of threaded rod that i have to turn down half of it to a smaller diameter and rethread it. I've never clamped on a piece of threaded rod however and was wondering what people use to be able to clamp it in a three jaw chuck without ruining the threads.
-JWB
--We Ain't Building Pianos (TCNJ Baja 2008)
Old 02-26-2009, 10:31 AM
Mcgyver is on a distinguished road
just hold it directly and take light(ish) cuts. threaded rod isn't precision stuff, should ok...worst worst case is you have to chase it with a die
if its more fussy, wrap some coppy sheet around it before clamping
if that isn't good enough, make a split bushing. take a round slug of metal a little larger than the thread OD, spot drill, drill and tap then split with hack saw or bandsaw. this will hold the threaded rod without damage but because of the amount of clearance you get with threaded rod it may not be that well centred.
Old 02-26-2009, 09:46 PM
djr76's Avatar
djr76 is on a distinguished road
Ive held them in 5c/16c collets just fine.
Old 02-26-2009, 10:11 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
if you have some brass shim stock you can give it a wrap
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 02-26-2009, 10:13 PM
Konrad's Avatar
Konrad is on a distinguished road
Take two nuts and cut about 4/5 thru...your jaws will push on the hex of nuts.
Konrad
Old 02-26-2009, 11:04 PM
Get a long coupler nut and cut a slit in it. Screw your rod in and then really reef down on the chuck jaws to close it up somewhat like a collet.
Old 02-26-2009, 11:08 PM
One of Many is on a distinguished road
If you can cut a 3/8 thread down and re-thread it, can you get away with drilling into it and tap it for inserting a locktited stud?
Depending on how concentric you need the threaded rod to your new threads. I don't aways trust the OD of threads, when it is the pitch diameters I want concentric. For a cheesy but reasonably accurate setup, I'll grip up any old scrap short piece of bar stock rod. Face, Drill and tap through it on center with the tailstock and it should run true as long as you don't remove it from the chuck. Then thread in the threaded rod and use a lock nut to keep it tight in the scrap rod.
Some hardware and fastener suppliers do offer reducing studs with mixed threads on either end. Another cheap and lazy option.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 02-27-2009, 12:06 AM
Konrad's Avatar
I find cutting it half way will tighten the nut so it's going be hard unscrewing the rod. A long nut like this would be better cutting it in half and using like split jaws. I have done this, most often I have regular nuts [two of them] cut about
4/5 thru into a hole, which is drilled very close to one flat of nut, about
1/32 away, then the nut is springy and it will always loosen up, use a good
grade nut..[alloy].
Konrad
Old 02-27-2009, 06:15 PM
sti2011's Avatar
sti2011 is on a distinguished road
Have had to customize more than a few nuts and bolts myself. If you have an emergency collet, drill and tap that, then your concentricity will still be there. This has also worked on parts that there is just nothing practical to hold on but a thread. I despise holding over the thread as they are usually not "really" a collet size and gage contact is near nothing. (will rip out if you are aggressive) Also with the collet depending how you run your spindle and tooling the part will tighten itself in, not out!
I've even done this with a three jaw chuck and it worked the nuts. Had a cut-down job on some really nasty moly bolts.
Old 02-27-2009, 06:42 PM
cam1 is on a distinguished road
Nice new Avatar dertsap, reflects the times.
regards
Can't Fix Stupid
Old 02-27-2009, 06:52 PM
dertsap's Avatar
Gold Member
its my tribute to the economy
CT129N Clamping kit ??? mindstorm88 Benchtop Machines 20 09-27-2010 07:32 PM
Newbie- Vacuum clamping ? bherr Work Fixtures and Hold-Down Solutions 4 08-04-2008 06:46 PM
Need Help!- Okuma O.D. to I.D Clamping pyropainter Okuma 1 07-04-2008 12:28 PM
Clamping Pressure Team Pierson Work Fixtures and Hold-Down Solutions 7 02-12-2007 01:08 PM
Part Clamping mattbyrne CNC Machining Centers 4 06-18-2006 11:45 PM
