Old 02-23-2009, 01:56 PM
Lumenium is on a distinguished road
Face milling for best finish on 4340 steel alloy on spline surface
I am machining a vertical surface 2" tall that follows a gradual spline profile using a Haas VF2SS vertical CNC mill and looking for the best possible finish. The material is 4340 annealed. I have tried a high performance 4 flute 20mm coated carbide cutter but I am not satisfied with the finish. I can't surface grind the piece because of the spline profile.
Does anyone have a recommendation for an end mill, an insert cutter or process that can give me a superior surface on 4340 with a finish grade N8 (125 micro-inch) or better that is truly perpendicular (no taper) to the horizontal surface.
Thanks for your ideas!
Old 02-24-2009, 06:43 AM
*Registered User*
Glacern is on a distinguished road
What speeds and feeds are you running? Are you getting chatter?
Consider trying a variable flute EM like a Hanita Varimill. A milling chuck may help as well... the more rigid, the better.
Old 02-24-2009, 01:56 PM
Glacem,
Many thanks for your ideas. I am going to try the Verimill cutter and an accurate milling chuck.
As for feeds and speeds, I have tried everything but my best results were using a 0.5" end mill 4 flute at 4000 rpm at 7 IPM. Is not the spec for the material but yields the cleanest finish.
I suspect it is chatter issue and I know it's not coming from the work piece so your suggestion on the mill and holder is promising.
I will let you know the outcome. I am also planning to try and electro-polish the piece when it's done to see that can do. Thanks again.
computation for surface finish in milling uperez General Metalwork Discussion 1 06-21-2007 03:33 PM
Bad surface finish with 3-D milling dylskee Haas Mills 44 06-14-2007 06:09 PM
3D Milling Surface Finish Problem TurboME General Metalwork Discussion 15 12-17-2006 10:32 PM
Surface finish after milling a mold ? Shizzlemah Moldmaking 1 11-24-2006 08:31 PM
RFQ: 35 parts 4340 steel Eddieweeks Employment Opportunity 1 08-21-2006 11:17 AM
