Hi All, I'm threadmilling my first 1/4-18npt and would like some help on the programming.The theadmill is a Morse carbide threadmill. I will be drilling the hole with a 7/16 diameter hsco drill and chamfer the hole with the proper size chamfer. The material is 303 ss. I would like to threadmill the hole without using a taper reamer. Any help on the program and the feed and speeds would be great. Thanks, Jim |
| Its 1/4 NPT, so its more like 1/2" in diameter. I have never done it so the feeds and speeds I have no idea. For the code, you need to rapid down into the hole, then do a helix which gets bigger as it goes up, following the taper. The helix should have a pitch of 1/18". Not sure exactly what your threadmill looks like but something like that should work. Also consider the fact that you may be able to get a tapered drill bit and get the tapered hole in one operation. Matt |
I just finished a job that is exactly what you are doing (may have done by now). I used a tapered cutter to go around the hole and set up the angle. Then used an NPT thread mill. Went down .250", threaded down to .550" in a normal thread milling manner at 700 RPM. I know some guys who didnt bother with putting in the taper first in aluminum. I was doing 30 holes in stainless. Better safe than sorry. |
| Did this kind of job a few years ago. Don't think I tapered the hole first, even with 303 ss. We had an NPT indexable threadmill from Kennametal. I seem to recall going to depth first and helixing up. I'm pretty sure they recommended that. Not bad at all. I think? Seem to recall? Pretty sure? LOL. Older than I was and it was a few years ago. |
Don't forget that when thread milling a taper thread, that the arc radius increases as you helically interpolate your way out of the hole, so just 'helixing up' won't leave the cutter at the correct place after 1 orbit, but will leave a 'snail-cam' shape. It is like climbing a spiral staircase inside a cone, every step up, the wall moves further away from the centre! If you need more help with the part-programming side, get back to me. Fred the thread |
| Thread Milling | Don Clement | Tormach PCNC | 23 | 08-01-2011 06:48 PM |
| Newbie- Thread milling | shake n bake | Mazak, Mitsubishi, Mazatrol | 2 | 01-09-2009 04:04 AM |
| thread milling | fourperf | Fadal | 2 | 11-20-2007 09:32 PM |
| Thread Milling 3/8-18 NPT | shawn | G-Code Programing | 13 | 08-26-2006 08:24 AM |
