Old 12-16-2004, 10:15 PM
scott m's Avatar
scott m is on a distinguished road
what is this toolholder?
Hello. I troll the USPO website quite a bit and ran across this wierd attatchment and cannot figure out what it's purpose is and wonder if anyone on this forum has any idea. I tried to access the specification page but it does not work for me . I see it has a dovetail slide and a bunch of adjustments. Scott.
Old 12-16-2004, 11:13 PM
Chagrin is on a distinguished road
Basically it's just an adjustable toolholder. Item #39 is a replaceable collet for holding the tool (which can again be indexed/rotated). Fig #5 is the same device but using a rack and pinion for vertical adjustment., and Fig #6 is again just an alternate (simpler) design.
Old 12-22-2004, 08:50 PM
scott m's Avatar
Thanks chagrin, it looks like an elaborate piece of junk with redundant features. Why would anyone want to index a tool in that thing unless it is used to hold stock for lathe milling or something like that. Scott.
Old 12-22-2004, 09:35 PM
HuFlungDung's Avatar
Moderator
Could it be some kind of a manually operated large radius forming tool?
Old 12-23-2004, 06:33 PM
scott m's Avatar
Possible huflundung, but I think it is probably something better left undiscovered . Lots of overhang on that thing. Scott.
Old 12-23-2004, 08:39 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
My guess would be it is for cutting key ways in shafting on a lathe..like a shaper.
Hence the vertical adjustments (or depth of cut) by way of the gear and rack setup. With #15 being the tool bit.
Old cnc tool holders glmoore General Metal Working Machines 8 05-31-2003 06:37 PM
