......Coolants are given shelf life limits because the emulsifiers that create the water oil chemical chains break apart over time. As to what you can do to increase the self life is a question for their chemical technical advice group. I would guess that if the coolant still mixes with water that it will not harm your machine i.e. rust ect. However I could not say if it will perform as well as fresher coolant. Blasocut is as I understand pure mineral oil coolant. Throwing away that much coolant would be expensive.
Steve...
LinkBack URL
About LinkBacks
