Old 01-31-2009, 03:50 PM
J.D.R is on a distinguished road
Bolt hole pattern for Fanuc 18i
Im wondering if anyone can provide a sample program to do a bolt hole pattern in a fanuc18i controller. I think i should be using a g72.1, but i cannot figure how to use it. I just get an alarm everytime i try it. Please Help
Old 01-31-2009, 04:33 PM
CNCRim's Avatar
Check your machine parameter manual, then turn it on otherwise I believe it an option you have to order.
Taig mill bottom base mounting bolt hole spacing pattern Hirudin Taig Mills & Lathes 4 01-20-2009 02:42 PM
programming bolt hole pattern jrogus CNC Machining Centers 1 05-23-2008 01:23 PM
Fanuc bolt hole macro Machinist3 G-Code Programing 4 05-23-2008 10:43 AM
Circle With Bolt hole Pattern JJsFab Torchmate 5 03-10-2008 08:28 PM
Bolt hole pattern with only a drill press sanddrag General Metalwork Discussion 7 05-04-2006 01:41 PM
