01-26-2009, 10:14 PM
Some dimensions like distance between the bearings, bearing bores and spacer bore between the bearings would help define your conditions.
Basic operation would be to use a boring head and machine the top and bottom bores in one setup to get the best alignment possible. This will take a custom boring bar for the bottom bore to cut upward. Interpolating a bearing bore is not as round which could distort the race if/when pressed in.
In a pinch for lightly held bearings. If the spacer bore were large enough and space between the bores short enough, one could set x,y center of the bore holes, using a woodruff cutter and interpolate the 2 bores from the top. Thereby taking advantage of the key cutter and machining in the spacer gap by dropping the cutter through the hole and undercutting the lower bore.
As you have found, when ever the part must be moved to a second operation, anything else will be a compromise to the new alignment. Assuming the block you have machined square and parallel. If you bored the bearing bore and the spacer bore in one setup, then flip it over and indicate in the spacer bore within a couple tenths, the secondary bore should still be close enough for the average application.
With a longer space between the bearings or smaller spacer bores that prevent access, flipping the part will require using a test indicator and indicating in something common to both ends to align the bores.
Creating a fixture that would hold it in 2 vertical planes would also be beneficial. Regardless how it is held, the concept is utilizing the through bore or 2 machined faces verified true to the Z axis, again using an indicator and if need be, resetting x,y zero to center on the common bore or faces. Be aware of short vise jaws and tall parts can tip with cutting forces too.
Simple center finders and edge finders just won't do if you expect near perfect alignment. The best bet is to either do it in one operation or set yourself up to make the secondary operation more reliable.
DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
