Hi everyone, I'm curious if our Haas VF-5 is set-up to do rigid tapping. The manual isn't available to us currently and I'm a bit unsure if the machine has this option. Are there any parameters than I can glance at that would give me an answer? Also, does anyone know if there is a way I can set-up this machine to trigger an air blowoff? I'm running some parts that need alot of operator intervention and if I could program the machine to follow a path while blowing air THAT would be fabulous! Thanks for any help in advance!! |
| There is a parameter for rigid tapping but I foget the number so you will have to search; it should have a 1 beside it to be turned on. In addition there is a setting for repeat rigid tapping. Regarding your air blast if you are not using the coolant pump you can use the coolant pump circuit to switch a 240volt soleniod valve to turn on air. Another way is to use the User M codes; read up on them in your manual. If you do not have a manual go to the Haas website; www.haascnc.com (I think) click on the Site Map and find Manual Updates. I can give you more info about User M codes next week when I get back from vacation.
If you machine is pretty new you may be eligible for a trial period of rigid tapping. This is done with a letter T. Turning On Rigid Tapping During Trial Period First turn the Parameter Lock (OFF) so that modifications can be made Press the Setting/Graph Key Press Home Key then Page Down Key 7 times to get to the (Editing) Menu First item is Parameter Lock (Turn Off) Press right arrow key to toggle to the (Off) position You can now go to the Parameter Screen to turn on Rigid Tapping. Also you need to turn on Setting (133) Repeat Rigid Tap Press the Setting/Graph Key Press Home Key then Press Page Down 3 times to get to the (Program 3) menu. Press the Down Arrow Key to get to the last item (133) Repeat Rigid Tap Toggle on by pressing the right arrow key Next you press the Parameter/Diagnosis Key Press the Home Key and it will take you to the (Common SW 1 Menu) Use the right arrow key to go down list to Item #5 Rigid Tapping Press the Emergency Stop button. Enter (1) on the keypad and press the Write/Enter Key Release the Emergency Stop button (Twist it) Press Reset/Power Up Restart button. Next turn the Parameter Lock (On) so that modifications can’t be made to any parameters. Press the Setting/Graph Key Press Home Key then Page Down Key 7 times to get to the (Editing) Menu First item is Parameter Lock (Turn Off) Press right arrow key to toggle to the (Off) position Press the Write/Enter Key You now have activated the Rigid Tapping Feature and have restored the parameter lock protection on your control. Programmable Air Valve: I have some information that may be useful for your programmable air valve. Just send me an private message if your are interested. John |
| What exactly is Rigid tapping? Why people always ask does it do rigid tapping? | cjchands | General Metalwork Discussion | 23 | 12-19-2008 08:19 AM |
| Rigid tapping Haas VF_0 | artin51 | Haas Mills | 4 | 09-17-2008 09:22 AM |
| Haas TM-1P Rigid tapping problems | dapoopta | Haas Mills | 3 | 03-18-2008 08:39 PM |
| Rigid tapping on Haas Mini Mill | rrossey | Haas Mills | 16 | 03-15-2008 09:29 PM |
| Newbie- Haas rigid tapping help | ShaggyVW | Haas Mills | 6 | 03-14-2008 09:09 AM |
