Old 01-26-2009, 09:09 AM
CJdave is on a distinguished road
Slot machining in bar
I have a job that requires a .265" slot 1.10" deep in the end of a 1" 1018 bar with a square bottom of the slot. I am thinking a slotting saw would be the best choice for this operation. I have never used a slotting saw before and I am hoping to get some recommendations from those of you with more experience on what is the right tooling and what feed/speed i can run it at. I will be running it in a bed mill with a centroid control.
Dave
Old 01-26-2009, 08:32 PM
Konrad's Avatar
Konrad is on a distinguished road
How many...
If just one, then milling with a slot drill...if you have allot, then a staggered tooth milling cutter full depth should work fine in about 1/10 of the time.
Konrad
Old 01-27-2009, 07:15 AM
50 pcs at a time with the possibility of a job repeat every couple months.
cutting a slot with a t-slot cutter cncuser1 Mastercam 11 09-09-2008 09:02 PM
MIS CNC Machining and tooling - General machining - Thermoform Molds modernprecision Employment Opportunity 0 11-23-2007 10:05 PM
Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill? weaston General Metalwork Discussion 7 04-11-2007 09:00 PM
Machining a Slot in Stainless Steel ngr1 General Metalwork Discussion 13 10-04-2005 08:20 AM
Lower Z axis in both directions when machining a single slot ngr1 Mastercam 8 08-04-2005 03:59 PM
