Old 12-03-2004, 12:04 PM
ngr1 is on a distinguished road
Sand blasting material for aluminum
Hello, I read somewhere that sand blasting can be used to alter the finished of aluminum as well as blend in minor imperfections and machining marks left by cutters (i.e. end mills).
In searching futher I have found material such as Glass Bead, Aluminum Oxide and Silicon Carbide can be used in the blasting process.
Does anyone have any info regarding this topic they could share?
Thanks... Norman
Old 12-03-2004, 12:39 PM
HuFlungDung's Avatar
Moderator
Add dry ice to the list, too. It might be hard enough to blast aluminum with, and no mess!
Old 12-03-2004, 01:06 PM
buscht's Avatar
buscht is on a distinguished road
Our suppliers use small glass beads to even our surface texture on aluminum castings. Sand is sharp and actually cuts into the aluminum skin causing pitting.
I'm sure glass beads will work well on machined aluminum parts
Old 12-03-2004, 04:11 PM
kenlambert's Avatar
kenlambert is on a distinguished road
aluminum oxide works well to clean up imperfections glass leaves a smoother finish
thanks Kenneth
web-www.lambertsrc.com
Learning CNC
Old 12-04-2004, 03:14 PM
NeoMoses's Avatar
NeoMoses is on a distinguished road
Glass bead will leave a nice matte finish. It is fairly easy to blend imperfections less than 0.005" or so. Taller discontinuities will take more time.
most types of true 'sand' are angular, and will leave a rougher finish. However, the rougher the material is, the quicker it will cut.
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
Old 12-06-2004, 04:01 AM
Mouldmaker is on a distinguished road
We use glass bead to give Aluminium a "Satin" like finish. It also removes minor imperfections (cutter marks) from the surfaces.
Old 12-06-2004, 03:06 PM
Thanks Everyone!
Old 12-06-2004, 04:37 PM
sbrpollock is on a distinguished road
I tend to stay away from anything but glass bead.
The "sand" type products that have sharp corners leave microscopic indentations with corresponding sharp corners in the bottoms of them. These (I've been taught) create what are called stress-risers that are the starting points of cracks and eventual failure.
Stress-risers are like the score you make in a piece of glass in order to cut it. It snaps right allong where the score is.
Glass Bead leaves indentations that are spherical in the bottom and does not introduce these stress-risers. In fact, many people I'm familiar with actually glass bead high stress pieces like conecting rods just to "relieve" surface stress and eliminate any stress-risers left by other processes.
Want a famous example? Though I never heard the results of any tests (this is pure speculation), the first thing I thought of when I saw that right front wheel break off of Kurt Busch's car (for no apparent reason) during the last race of the Nextel Cup Championship, was If it had been "Sand" blasted at one time.
Patrick;
The Sober Pollock
Radius material setup MikeA Mastercam 2 04-25-2005 09:46 AM
Help with warping material snaggletto General Metalwork Discussion 11 04-08-2005 10:22 PM
Drilling a perpendicular hole in drill rod material ngr1 General Metalwork Discussion 12 12-04-2004 09:16 AM
how to mill 7075 T6 sheet material gcamlibel General Metal Working Machines 11 09-08-2004 01:06 PM
Material removel mace PTC Pro/Manufacture 5 09-10-2003 03:31 PM
