Old 01-24-2009, 05:55 PM
GerPen is on a distinguished road
Drill chuck holder
My MicroLux mini mill came with a (MT3)drill chuck which attaches to the spindle with a MT3 shank and draw bar. How does the shank connect to the
chuck? Is it a press fit?
Thanks, I'm just getting started.
Old 01-25-2009, 11:35 AM
Konrad's Avatar
Konrad is on a distinguished road
Originally Posted by GerPen View Post
My MicroLux mini mill came with a (MT3) How does the shank connect to the
Drill chuck usually has tapered hole and shank fits tight, pressed in and hard to take apart.
Taking them apart is usually done with tapered wedges pushing them apart from behind.
Konrad
Old 01-25-2009, 02:16 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Or, you can use a drift or pin punch through the chuck jaws to knock the arbor out of the chuck.
CR.
Old 01-25-2009, 05:49 PM
Thanks for the replies. I think I'll press the chuck onto the arbor and use it as a dedicated unit.
Need Help!- Can this drill holder be repaired ? vroemm General Metal Working Machines 5 10-31-2008 07:11 PM
remove drill chuck jwallace Benchtop Machines 8 02-23-2008 01:06 PM
Setting up a gang bang drill holder joseavina76 General Metalwork Discussion 2 10-02-2006 10:28 AM
Chuck Drill Chuck Alignment TomV Mini Lathe 5 04-27-2006 01:20 AM
Drill chuck on my router? Should I? borrisl DIY-CNC Router Table Machines 9 01-29-2006 02:03 PM
