Hello Group, I spec'd. out a 7/8-20UNEF male thread on an aluminum part and called out for a Ø.800 ±.005 thread relief groove. The shop doing the work said the groove wasn't small enough for the tool not to clear. Machinery's Handbook says minor dia. is .8155. I am .015 smaller than nominal, where did I go wrong and how does everyone else calculated thread relief grooves? Thanks in advance, Pat |
| I don't calculate, Im a machinist and it's given to me.. If I was doing the work for you I wouldn't complain, the tool should clear,...if the tool might have a super sharp V point, then it might just scratch the groove? The tool should always have a slight radius on the end then it should stay clear. Konrad |
| Hello Konrad and thanks for the reply. They said the tool would just scratch the surface and they used an CNC lathe with a standard threading insert, so I assumed it would clear also. I may back the diameter off by another .005 or .010 just so there are no questions in the future. Hey, my wife is Canadian and from Edmonton. Her dad/family left there in 1963 and came to So. California to work in the oilfield machine shop business. Thanks again, Pat |
| Pat, sure, another .010 or .015" wouldn't hurt, just make sure you have a Rad. U undercut. Interesting...Edmonton now is a great place doing business in the oilfield, especially for the tar sand in Fort McMurray. My daughter has a job there in chemical engineering. Konrad |
| 3d relief from bitmap | walter | DIY-CNC Router Table Machines | 28 | 05-11-2012 08:27 AM |
| 3d relief | senor J. | DIY-CNC Router Table Machines | 49 | 04-25-2012 02:42 PM |
| Relief Cut is Cut Above the Wood??? | mlammert | Mach Software (ArtSoft software) | 7 | 04-15-2008 08:02 AM |
| 3D Map Relief | xtaffy | General CAM Discussion | 3 | 03-14-2005 10:24 AM |
