| When you say slot cutter I assume you are talking about a slotting/slitting saw? If this is the case do you know of a good source. The only one I can find is .128" thick and 2-3/4" in diameter. I really need atleast a 3" in diameter cutter and that would depend on the size of the arbor. Then what do you do at the ends of the cut where they are curved instead of the 1.5" overall depth? |
| What kind of material are you milling into? I would do as Mitsui had said. Use a disk cutter. I don't know if they make inserted disk cutters in this width. I have always used a carbide saw 3" in diameter. Depending on what you are cutting climb milling is usually a must. We also had to remove the radius at the start and end of each cut. Most of our slots were only .042" wide and and about .25" deep so we used a spindle speeder to get the RPM needed to mill out the radius with and endmill. You pick away at it like a staircase starting at the top. Stevo |
| If you are doing just one it would be fastest to just mill the slot. preferably from both sides so you only need to go down 0.75". High spindle RPM and a Airmist coolant to blow the chips out. Take no more then 0.05" depth each pass and also feed it back and forth. SHould be easy enough. |
http://ecat.secotools.com/ Search for a disc cutter named R335.10 At the ends you can do a simple contour with a 3/32 endmill ,working your way down to depth.
__________________ Stefan Vendin |
| Slitting saws or cold saws work best,...but tooth form should be ground for alum. for best results. For alum. you need coarse teeth. On your .128" blade....grind down side to about .123"...it will cut oversize a bit. Konrad |
| For a slot that deep it seems to me you need a slotting cutter at least 4" in diameter, but even with that you'd need to have an arbor of less than 1" diameter. Not likely. My Valenite catalog shows you'd need a 6" outside diameter one to get that depth of cut. Their V350 A 12 60 D14 would do the trick. It's got a 1.5" hole, so you need an arbor that size. The 14 inserts you should get for it would be VSG 3.10 N 30-SC. Those are .123" wide, but the likely overcut would make your slot just about .125". If they run tight you could try the VSG 3.18 N 30-PG. Those are .125" wide, exactly. |
| Problem- milling thin wall brass tubing | jackie_burton@m | General Material Machining Solutions | 11 | 09-29-2008 03:46 PM |
| Need Help!- Helical milling a slot | kevinheez | Surfcam | 4 | 05-02-2008 07:14 AM |
| Simple slot milling problem | jwknow | Mastercam | 5 | 01-22-2008 05:03 PM |
| milling deep pocket | barnesy | General Metalwork Discussion | 8 | 09-16-2006 05:00 AM |
| Save 100% on Tooling cost and set up time on milling thin parts with the Doo-Bee Stop | DynaPowernamics | Product Announcements & Manufacturer News | 5 | 05-28-2005 09:17 PM |
