Old 01-23-2009, 06:06 AM
osiris999 is on a distinguished road
can stub acme be changed to acme
so at work tonight i had some parts that i thought needed 3 pitch stub acme threads. so i machines all of them with a 3 pitch stub insert. a guy at work just called me and told me they were so posed to be acme. from my understanding acme is just deeper. so can the parts be fixed if i chase them with an acme insert?
Old 01-23-2009, 02:14 PM
307startup is on a distinguished road
The flank angles should be the same, but the width of the tooth at the bottom may be different due to the nominal thread height. Compare taps or inserts to make sure. If you have to, look up the info on the manufacturers website.
Old 01-24-2009, 12:45 AM
it can. first they wanted to scrap all the parts because our manual machines can only go down to 4 pitch. i guy who just started and knows nothing about programing and all managed to convince them to let him chase them in the cnc i made them on. they said it couldnt be done lol. took him 10 hours to do the 13 parts but he got them all.
Old 01-27-2009, 04:08 PM
What kind of CNC lathe are you using? Almost every CNC lathe I've ever ran across has the ability to rethread by picking up an existing thread. Hell, that's exactly what I did for a year at one company, chasing threads on components that had been damaged and wouldn't gauge, so they could be reused.
Old 01-28-2009, 02:00 AM
aaron p's Avatar
aaron p is on a distinguished road
Interseting. I was told on the Mazak E-410 Integrex I run at work that it wont pick up the thread if you take the part out and put it back in. Dosent know the start point I guess? I work at a huge oil field parts manufacturing plant and we do tons of different acme threads. Stub, Standard, Modified Brown Oil Tools Acme, and a bunch of others.
"We can't solve problems by using the same kind of thinking we used when we created them", Albert Einstein Thinking outside the box 24/7........
Build Thread- stub acme roncnc General Metal Working Machines 1 04-15-2011 06:30 PM
anyone cutting Stub Acme threads? WOLOG General Metalwork Discussion 3 11-18-2010 06:24 PM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 05:47 AM
Ab Acme Nut??? MMT CNC Plasma and Waterjet Machines 0 02-27-2005 08:53 PM
what acme tap do I need for the Enco ACME rod? AJ_Mac2001 DIY-CNC Router Table Machines 15 03-08-2004 07:24 AM
