Old 01-22-2009, 09:19 PM
wrechin2 is on a distinguished road
How to cut say 3" holes in 1/2 aluminum plate???
What is a way to cut multiple diameters of holes in plate aluminum?? I will finish them with boring bar. Thanks to all the reply.
james
Old 01-22-2009, 09:26 PM
307startup is on a distinguished road
There are multiple ways to cut those holes, just depends on how exact they need to be, or what equipment you have.
You could use hole saws mounted on an arbor and chucked up in your milling spindle using an appropriate collet, if you have a manual mill and then finish to size using your boring head.
You could use interpolated circular milling to cut the holes to size using a cnc mill and finish to size using your boring head.
You could cut them out using a plasma, laser or waterjet.
It all depends on your equipment at hand, really.
Old 01-22-2009, 09:35 PM
I have a manual bridgeport and need to rough cut 75, 80, and 90MM holes. Would like to get as close as possible and finish with boring head. Is there some kind of inexpensive adjustable hole cutter? Thanks.
James
Old 01-22-2009, 09:40 PM
Well you could use a fly cutter and a special hand-ground HSS tool bit for trepanning the holes. That's about as inexpensive "adjustable" hole-cutter as I've ever seen.
Either that or try Miracle-Grow on smaller drill bits
Old 01-22-2009, 09:42 PM
Really, I would consider the hole-saws on an arbor. It's pretty impressive what they are capable of. You just have to figure out the proper feeds and speeds and you're good to go. I have used them on a 4th axis lathe with live tools for some of the products we were manufacturing and they work amazingly well for what they are.
Old 01-22-2009, 10:16 PM
The thing is, I would have to buy multiple hole saws or spend alot of time boring due to the differnce in size. Where can I see a pic of the trepanner? Where can I get one cheap? Thanks for your help.
James
Old 01-22-2009, 10:21 PM
Arquibaldo is an unknown quantity at this point
I agree - hole-saws, definitely.
You can buy then up to 100mm in diameter
(see http://www.starrettonline.com/produt...D=61&prdID=682 for instance)
They can punch a hole thru a 1" steel plate - alu should be easy.
The arbor is hexagonal, so you can grab it very securely with a standard "jacobs" type
chuck
Old 01-22-2009, 10:29 PM
Well,
Guess a hole saw is it. Thanks guys!!!
Old 01-24-2009, 03:23 AM
jschmitt is on a distinguished road
Be sure to drill clearance holes around the inside to clear out the chips
Old 01-24-2009, 08:09 AM
Thanks!!
  #11   Ban this user!
Old 01-24-2009, 08:40 AM
USMCPOP is on a distinguished road
Something like this might work for you:
http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=57136082
  #12   Ban this user!
Old 01-24-2009, 10:13 AM
Thanks!! That helps. I am ordering some1-2-3 and 2-4-6 blocks there on Monday. They have a store 1 mile from work. Can't beat the free shipping especially on things that heavy!!!
Need A Quote- RFQ: Small (3"x5"x1/2") part from dimensioned drawings in Aluminum or stainless octathorpe Employment Opportunity 6 06-23-2008 07:14 PM
1" holes in 1/4" 304 SS plate. Loading General Metalwork Discussion 5 10-25-2007 07:33 PM
How to tap 1000 2-56 holes in Aluminum? Driftwood General Metalwork Discussion 33 08-21-2006 01:41 PM
Milling holes in Aluminum walter General Metalwork Discussion 16 02-14-2006 10:58 AM
Drilling Holes in Aluminum JavaDog General Metalwork Discussion 23 09-08-2005 09:29 PM
