Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: Question about Feed/Speed Chattering
    Sep 2004
    Im using a 3/8 2-Flute Carbide Endmill. Plunging with full cutter width at 80mm/min, then feeding at 350mm/min down the X axis.
    The plunge works great, no chatter. Most of the run down X is find too. Its the transition from the plunge to the X-feed. It hums BAD right at that moment. All the chips on the workbench hop. Im afraid that will damage my mill. Comments?
    How could I avoid all the chatter I am getting between the plunge and x-feed?
    Thanks,
    Swami
    Moderator HuFlungDung's Avatar
    Mar 2003
    How deep are you going in one pass?
    You might try retracting from the hole just to make sure the cutter has cleared its flutes properly. Then, move a few thousandths in the X direction and plunge again, then feed. Us professionals would likely use some kind of a zigzag or helical entry to make the plunge opening larger than the cutter to start with.
    You might also ramp down for the full length of the cut, then come back at full depth, fixed depth.
    Sep 2004
    Thanks so much! That was educational. I have absolutely no one I can learn from "in person" A lot of this is being learned through the "stumbling fool" method!!
    Thanks,
    Swami
    Gold Member
    Apr 2003
    Ohio, USA
    Hey Man, are you making fun of my education, experience and pain are the best teachers
    Sep 2004
    LOL
    I forgot to respond that its doing cuts of 1.5mm in a pass with seemingly no difficulty. I actually have no idea how far I can push it. RPM is limited to 2400 (Sherline 5400)
    Gold Member
    Apr 2003
    Ohio, USA
    I would not think that .0004 would offer any problems up-to your max of 2400rpm. If it is cutting 1.5mm (.059) for us Imperial fans effortlessly then that is a great opportunity to increase the feed by 10% and try that.
    Aug 2003
    az
    LOL, took the words right out of my mouth!
    There are probably a more than a few of us stumbling fools here.
    Mar 2003
    To be an expert, you have to make all the mistakes yourself, first.
    Sep 2004
    Quote Originally Posted by Ken_Shea
    I forgot to say that I am already at my maximum feedrate (13 IPM).
    I would love to go faster, but it would obviously be a hassle. I could probably rewire my unipolar steppers to work with a new controller...
    Since I am at my max feedrate, can you also effectively increase feed by taking deeper cuts? Is it literally the same thing (asking the cutter to do more)?
    Swami
    Gold Member
    Apr 2003
    Ohio, USA
    Swami,
    I checked some of the feed rates and with what you mention you are (according to this ) going to fast, this can also cause some of the transition roughness you mention. This experimentation is necessary for you to understand the limits (and they all have them) of your machine.
    If you do not have ME Consultant 2.0 I would highly recommend it, it is not a answer all absolute but it is a great help for those of us that are new to this type of need.
    just do a google search for it.
    Attached Thumbnails Attached Thumbnails Question about Feed/Speed Chattering-image3.jpg
    Sep 2004
    Thanks thats a great tool.
    So is it the RPM that is holding me back from using higher feeds?
    Swami
    Gold Member
    Apr 2003
    Ohio, USA
    Available RPM is one of the factors to be sure, in your case if you had 4000 RPM available feed would jump from 9.7 to 16.2 and if 6000 RPM then 24.2 so you can see the difference. You can play around with what ifs on ME 2.0 so give it a go and it will also help you learn to use it to your best advantage.
    Aside from RPM there are many other limiting factors, rigidity of the fixturing, manner of fixturing, weight of the machine, horse power, machine condition, quality cutters vs cheap cutters, controller settings, length of tools and the list goes on.
    If you have long cutters leave no more then necessary sticking out, but be careful that you have your tool length and/or top of material settings correct.
    I am not particularly familiar with the Sherline 5400 but I believe it to be of good quality but a light hobby machine so you might try backing off the .059 DOC to say .030 and give that a try.
  • Page 1 of 2 12 LastLast
    1. 3/4" MDF feed/speed question
      By victorbl in forum DIY CNC Router Table Machines
      Last Post: 08-26-2011, 01:15 AM
    2. Extremely basic machining question.
      By touser in forum General Metalwork Discussion
      Last Post: 06-19-2005, 01:51 AM
    3. Question about power supplies
      By dowling177 in forum General Electronics Discussion
      Last Post: 01-28-2005, 08:01 AM
    4. Hobbycnc controler question
      By chas in forum Hobbycnc (Products)
      Last Post: 09-09-2004, 06:00 PM
    5. HF lathe question
      By rs1300 in forum General Metal Working Machines
      Last Post: 01-19-2004, 12:22 PM
