well im just hoping to get a few suggestions. i was supposed to machine a drives shaft with a 2.5 inch diameter ID and when i started working on the stainless (316) everything just went to hell in a handbasket. the chips got pushed into the part while i was boring and accumulated so that my insert started disintigrating. i was going about 200 rpm and about .010ipm with a .07 depth of cut on a htaci seiki cnc. by the way my boss made me use a 1.375 drill to start the hole. which i thought compounded the problem. any suggestions would be appreciated even slap me upside the head !!!! ![]() i dont mind criticism i just want to learn |
| You most likely work hardened the material. The only way to solve that is to take a large enough cut to cut under the hardened scale. As far as speeds and feeds go, your feedrate sounds good (maybe push it a little harder for roughing) but your rpm is WAAAAY to slow. At 300 sfm - which is a good round number for 300 series stainless - you should be at roughly 900 rpm. 316 can be a bear to cut if you're not sure where you need to be. Good luck
__________________ I don't know much about anything but I know a little about everything.... |
| turning 430F grade stainless steel | callganesh | General Metalwork Discussion | 2 | 11-03-2008 03:25 PM |
| Turning 321 Stainless | Bill308 | General Metalwork Discussion | 7 | 11-13-2007 07:17 PM |
| 316 L Stainless | CNC_BOB | General Metalwork Discussion | 2 | 10-26-2007 12:48 AM |
| Stainless turning job | fastolds | Employment Opportunity | 12 | 06-13-2007 12:52 AM |
| Turning questions - 304 Stainless & 4130/4140 Chromoly | K-fab50s | General Metalwork Discussion | 13 | 10-24-2005 08:53 PM |
