I just got my first actual machining contract today and had a question about surface finish. I am going to be making 100 small parts on the lathe and it specifies 64 rms. So the question is, what does the finish look like? |
| This is going to be tough to describe. A 63 finish falls somewhere between a very nice finish (32) and a "good enough for production" finish (125). The finish should be fairly smooth, no chatter. You might want to invest in a set of surface finish standards, which are simply a set of blocks machined to various surface finishes. These blocks can be used visually as comparators, or used to calibrate surface finish measuring equipment. Here's one link, there are many more (cheaper) ones out there, I'm sure. http://www.edmundoptics.com/onlineca...productID=2468
__________________ Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers |
| THe ID of a PROPERLY refinished auto engine con rod is 50-64. Too smooth here and not enougt "bite" into the bearing to keep it from spinning. Too rought here and poor size control plus poor heat transfer out of the bearing into the rod. |
| Surface Finish | life3970 | Mini Lathe | 2 | 11-07-2007 12:00 PM |
| Surface finish | skmetal7 | Mini Lathe | 7 | 09-10-2007 12:56 PM |
| Surface finish | chakaloso | General Metal Working Machines | 0 | 06-12-2007 08:54 PM |
| Surface finish | d.a.v.e | Mechanical Calculations/Engineering Design | 1 | 11-10-2006 01:35 PM |
| 32 surface finish | mroy0404 | General Metalwork Discussion | 4 | 05-28-2006 09:02 PM |
