first of all,aluminum is not the best choice for fine detail which needs a lens quality high polish,usually hardened tool steel,stainless or s-7,the only way i would do it if i had to would be take a small peice of cast iron and cut the form on it and use that with a fine diamond compound,we use a dme profile,or dipofile,to move the cast iron form back and fourth,cast iron is soft and is porrous to hold the compound,on alunimun if u use anything other than diamond compound u will scratch it,good luck,thats my 2 cents
LinkBack URL
About LinkBacks
