I have an application where i need to mill a 1.6mm diameter hole to a depth of 5mm in a 15-5 PH steel component. The accuracy of the hole is +/- 0.005mm. I have been trying to interpolate using a 1mm endmill which has a flute length of 2mm and the back is relieved. I' am not able to get consistency and each component comes out differently. I use a Deckel Maho machine which is very accurate. Can anyone help me with an alternative process idea or some method where i can get consistency in hole size with my present method ? Using a Reamer is tough as the positioning accuracy is also very important and a reamer usually takes the drill position so the drill can guide it to wrong position. Just letting you guys know in case somebody thinks of reamer as an option. Thanks |
| Drill, interpolate a very small amount undersize to get the position precise, then ream; the reamer will follow the interpolated hole.
| Carbide Reamers work good. one other thing you can do if your having problems is use a precision Boring head, you might have to make a bushing to hold a solid carbide boring bar for the boring head as most have small 1/8 shanks. Micro 100 sells boring bars that would work for your application. if you have a 5/8 dia hole in your boring head you can use hardinge tooling split bushings to hold the bars they make them in all dia and hold boring bars very rigid |
| +1 on the drill/bore/ream. Just have to be very careful with reamer runout. Carbide, yes; ±.005mm about uses up the +.005mm tolerance the reamer manufacturer usually makes them to. Measure all your reamer carefully! |
| How small a hole can you plasma in 11 ga? | Stuff-Builder | CNC Plasma and Waterjet Machines | 7 | 01-20-2008 10:42 PM |
| How accurate is steel punching? | taws6 | General Metalwork Discussion | 7 | 05-07-2007 11:10 PM |
| small, deep aluminum hole | Hoeken | General Metalwork Discussion | 5 | 04-27-2007 05:52 PM |
| Boring a Hole in 4140 steel | ricotututi | General Metalwork Discussion | 13 | 10-05-2006 11:15 PM |
| Accurate Hole Layout & Drilling | vacpress | Mechanical Calculations/Engineering Design | 11 | 04-19-2006 12:21 PM |
