Old 12-25-2008, 10:21 PM
yaji63 is on a distinguished road
Rotating NC program in over Y Axis
Can someone help me in giving info about any software which can rotate an NC program over Y axis by 180 degrees. This is a case where if i have a program running from Bottom to Top in Z axis it has to change to Top to bottom and the X axis Co-Ordinates will change from Negative to Positive and vice versa.
Cimco editor can only rotate in 2 axis (X and Y point 2 axis rotation) or even X and Y mirror. The case i' am looking at is similar to making Z mirror but this is rotation of 180 degrees and not mirror.
Thanks in advance
Need Help!- Why I program in 4/5 axis? EL DUKE EdgeCam 1 04-29-2010 02:07 AM
Newbie- Foam Cutting Rotating Axis professionalcnc Foam Cutting Software 1 10-30-2008 01:38 PM
Need Help!- PP for iTNC530 (5-axis) (rotating head B and table C) for edgecam jorphi Post Processor Files 0 03-12-2008 10:35 AM
Need Help!- Rotating axis addition - Questions about lathe chucks. tahustvedt DIY-CNC Router Table Machines 1 03-06-2008 12:25 PM
Rotating Nut Ball Screw for dual X axis AeroKam DIY-CNC Router Table Machines 2 08-09-2005 11:05 PM
