Old 12-15-2008, 01:13 PM
SRT Mike is on a distinguished road
What's the finish they put on aluminum fire truck control panels?
I was watching a show on TV, I think it was "how its made". Anyway, they were cutting an aluminum panel that was going to hold a bunch of switches and gauges. They put a finish on the aluminum that looked like a bunch of overlapping circles.
What is that finish called? I thought it was "engine turned" or something? Of course when I google "engine turn aluminum" I get all sorts of links about maching AL on an engine lathe
I have a trade show coming and I want to machine some fixtures in aluminum. They always get beat up so I figured a nice coarse turned finish like that would look OK even after being scratched. But how to achieve it? It looks like it was done with something like a wire wheel or maybe a sanding disc, either in a hand drill or maybe using an angle grinder?
I'm sure someone knows what I'm talking about - any pointers?
Old 12-15-2008, 01:15 PM
Med-Pac is on a distinguished road
Any chance of some pictures? That might help.
Mike
Old 12-15-2008, 01:40 PM
LinearMotionFan is on a distinguished road
Mike,
Here's the "How It's Made" segment that shows that. It's 2:30 into the video.
Old 12-15-2008, 01:42 PM
Hi Mike,
Here is the only pic I could find
Old 12-15-2008, 01:43 PM
Hennessy is on a distinguished road
i don't know what they call the finish but i think it is done with an orbital sander...
Old 12-15-2008, 01:45 PM
Originally Posted by LinearMotionFan View Post
Mike,
YouTube - How It's Made Fire Apparatus
Bam! That's it! Thanks so much! .. oh man, I was searching forever it seemed and you go and find it in minutes! Awesome - looks like a sander it is - that's precisely the finish I am trying to achieve.
Old 12-15-2008, 01:46 PM
Yup, that's it too - I found some sites mentioning using a wooden dowel but they were talking about a jewelers finish and it would take hours with all the parts I'd need to do.... I wasn't sure the best tool but from the pics and video, it looks like an orbital sander and just regular sanding pads will be perfect.
Thanks guys!
Old 12-15-2008, 01:50 PM
SCRAPWOTSCRAP is on a distinguished road
I believe the circular pattern is referred to as "engine turned pattern". Didn't trust my memory (with good reason) so I checked. For your reference:
http://ornamentalturning.net/craft/
Old 12-15-2008, 02:08 PM
I have a feeling that an orbital sander will give 'fuzzy' circles; try it with a simple rotating disc using a soft backing behind the abrasive.
I have done a very similar thing on a much smaller scale using a pencil eraser and grinding past with the pencil mounted in a drill press.
Old 12-15-2008, 08:50 PM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
"engine turning", it's done with a drill or a drill press, high speed, scotch-brite pads or sandpaper. Simply spin the abrisive wheel about 1000 rpm and press down, move have the diameter to the right, press again and repeat. At the end of the row, move down half the diameter and start over making sure you stay linear for the true "engine turned" look. (vary step over and alignment to preference)
It's old hot rod stuff. You'll see a lot of firewalls in custom cars with the same finish. Don't know where it originated, but from my experience, that's where it's most popular, that at fire trucks! lol
  #11   Ban this user!
Old 12-15-2008, 08:55 PM
acondit's Avatar
acondit is on a distinguished road
We used to do the same thing (with a much smaller rotating disc) to rifle bolts. It was called jewelling. I used to have a tool that held a small (approx. 1/4" diameter) abrasive imbedded rubber piece that was pressed against the bolt. I may still have something similar for my Foredom.
Alan
http://www.alansmachineworks.com
  #12   Ban this user!
Old 12-16-2008, 11:26 PM
Big S is on a distinguished road
I was thinking it would be very easy to do on a cnc mill or router, just like in the drill press only you can program in the spacing and let it do the hard work for you.
Shannon.
Excitech 1530 Router owner,
WWW.REMAIN.CO.NZ.
Need A Quote- Aluminum sheet cuttting into small panels for electronics rjmmusic Employment Opportunity 13 12-02-2008 12:48 PM
Material for Poly Tank for Fire Truck htishop Mechanical Calculations/Engineering Design 3 01-11-2008 10:42 PM
RFQ: Beadlock Rim & Rings Radio Control Truck (Crawler) DrasticSports Employment Opportunity 10 09-10-2007 05:54 AM
How to finish aluminum? jason_n DIY-CNC Router Table Machines 11 03-29-2007 11:04 AM
RFQ - aluminum truck emblem bezels (short runs) joemartins Employment Opportunity 3 07-11-2005 09:15 AM
