Can anyone give me an idea of the force exerted on a workpiece by an endmill (say, 1/4" diameter) in aluminum? Better yet, how would I go about determining this for an arbitrary material, feed rate, diameter, etc? I'm trying to calculate the torque that will be exerted on my rotary table so I can calculate appropriate limits on tool size/distance from center... The table has a maximum capacity of 250 inch pounds. I'm thinking I may only be able to cut on the axis center... |
| This is assuming a lot, but... Slot milling Aluminium, 6 mm 2 flute carbide stub end mill, 1xD DOC, 5,300 rpm, 300 mm/min feed rate ~ 210 N force. (I happened to be browsing an NSK catalog and stumbled apon the example!) Best regards, Jason |
| http://metalworking.com/shareware.html download machine zip
__________________ A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org |
| I was only going to get a 6" chuck, so it looks like I'm going to be in good shape! |
as you note, you can vary the torque by what radius you cut on the RT, however this isn't practical as the plan usually determines the radius, not the table's torque constraints you would cut the distance from the axis you need and vary the torque but varying the force by varying the depth of cut. in practical terms, I can't see an RT made light enough that you wouldn't bust the 1/4 end mill long before you damaged the table Last edited by Mcgyver; 12-12-2008 at 03:53 PM. |
| Thanks, great info! I can definitely agree that most rotary tables could take the force no problem, but as this is really a home made job it's not quite true. The max torque on the gears is only 300 inch pounds, where as most other rotary tables seem to be rated in large numbers of foot pounds. At 6 inch I can only apply 50 pounds, which isn't all that much, sadly. If I stick to small end mills, I think I'd be pretty safe. I don't have in mind a particular part I am trying to make, it's more that I am trying to determine the limits of this thing so I don't destroy it playing around. |
You should be alright using such a small diameter tool, assuming the table brake is functioning. but it would have been helpfully if you told us what make/model of table you were using? |
| Drawbar force (MT3 & R8) | The Blight | General Metal Working Machines | 2 | 02-14-2009 11:46 PM |
| pressure vs force | pit202 | Haas Lathes | 0 | 10-10-2008 02:30 PM |
| how to figure force? | jessslp05 | Linear and Rotary Motion | 2 | 05-05-2008 08:43 PM |
| Need Help!- Force toolchange ??? | Lval | EdgeCam | 5 | 04-28-2008 02:33 AM |
| Need to know how much force in psi | RedDog22 | Mechanical Calculations/Engineering Design | 17 | 01-05-2008 04:32 PM |
