Old 12-10-2008, 07:35 PM
kennyrobotics is on a distinguished road
Milling racks on mill
hi, a mate wants rack milling in an pneumatic ram piston rod, only problem is i only have an haas vertical he wants an MOD 2.5 rack milling in the rod, can you get an slot drill what has the tooth angle on?? if you had to do it what would you do??, i know its normally done on an horizontal, but if i can get tooling to do it on my mill i can get alot of these to do.
please post back
regards
kenny
Old 12-13-2008, 10:01 PM
Les A W Harris's Avatar
Les A W Harris is on a distinguished road
Conical Tapered End Mill.
please post back
regards
kenny
Presume 20° PA for metric module? Conical tapered end mill, 20° per side, .062" small end dia, 1/2" L.O.C.
Cheers, Les.
Old 12-14-2008, 05:49 PM
ctate2000 is on a distinguished road
Pretend your vertical is a horizontal. Stand the shaft in the vertical position and mount side mills with the correct profile in your spindle.
Old 12-16-2008, 02:18 PM
can't really the rod is 500mm long, thanks for the advise
Need Help!- gear pitch for racks markus_detroy DIY-CNC Router Table Machines 0 03-16-2008 10:13 AM
Racks & Pinions with gear box eloid Linear and Rotary Motion 11 03-06-2007 01:33 PM
Tooling Falls off Racks? nonnsgranite General Material Machining Solutions 3 08-02-2006 02:09 AM
Racks and Spur Gears -- HP Laserjet Motors High Seas Linear and Rotary Motion 5 01-30-2006 03:42 PM
Please share your experiences with ballscrews, leadscrews, and racks journeyonline Linear and Rotary Motion 1 01-19-2006 04:00 PM
