Im using a custom ground step drill pictured below to drill and countersink a blind hole in aluminum Its been giving me trouble from the get go Im feeding to +.100 of final depth, retract to clearance, rapid back to +.120 final depth, then feed to final depth and dwell a half second hitting it with M.O.M. oil every 2 seconds this is coded long-hand the first "peck" is S7000 F15. the finish "peck" is S3000 F7.5 the upper diameter of the c-sink is .300 I was breaking these drills left and right till I got to these feeds and speeds now the problem is the taps are breaking these taps were doing over 2000 holes each and never broke, now two have snapped in as many days the tap breaks off in one hole on the frame, but the remaining un-tapped holes all look fine, the tap is an oversized HSS 8-32 spiral flute for helicoil inserts I had no idea these blind holes would be so problematic I use a similar step drill on another frame with thru holes and it just keeps going and going... I decrease the speed on the last feed move because the countersink doesn't like high rpm I think the fact that the countersink and the drill tip are both cutting the last .100 simultaneously at low rpm is causing the trouble Anybody got some insight on this combined operation for thru holes? a better tool maybe? a coding tweak? thanks in advance Kenny |
| I've used many form drills and form endmills. what I have found is that pecking doesnt work as well as its just like drilling through a pilot hole and the form tool will bounce around. if you can't drill one shot I am guesing the tool was made incorrectly however its been working so what I would do since you are pecking is make sure your first peck is short enough so it doesnt touch the bigger dia. only the pilot, then way on your final peck it recenters/ and gets tool pressure on the pilot and then cuts the the big dia. if yuor using a canned cycle did you happan to change the start distance? for example if you had a start of Z0.1 and changed it to Z0.150 where the peck stops for its next peck will be different. Remember always calculate the peck from were your retract point is not from zero as a example like with .100 peck depths if you started at Z0.1 and goto Z-0.350 your first peck is at Z0.0 Z-0.1 Z-0.2 Z-0.3 Z-0.350 if your retract starts at 0.150 your first peck is Z0.050 Z-0.05 Z-0.150 Z-0.250 Z-0.350 I have had guys/including myself change the z start after the job gets running to save time not thinking about were the pecks finish on each peck. Form tools this can be very important. As far as tapping blind holes use a roll tap they are stronger and don't make chips they are just as good as thread milling but less expensive. I assume your doing this on a cnc mill as you said spindle speeds of 7k. also how are you holding the drill and the tap? drill chucks dont work good for step drills. use a quality collet holder |
| thanks delw for taking the time to help out, the drills major diameter is .325 so I cant hold it in a collet, Im chucking it for now the machine is Haas GR408 I coded the drill cycle long-hand as a subroutine and the 1st peck does stop before the major diameter engages |
| the final peck does start before it makes contact with the major dia.? I would advice buying the er coller tools,it will make all the differnce in the world and its worth every penny. I dont even drill with a drill chuck anymore unless its less than .062 dia. I have noticed a huge tool life increase and far less chatter and walking problem. Fake Edit your running a haas router never saw one till just now. pretty damn cool machine. It does have a ct 40 taper tool holders you should be able to get a tool holder with a er series collet from us shop tools pretty quick. http://www.usshoptools.com/current_y...r%20collet.pdf It may also be a rigidity issue at high speed and you might have to slow the rpm way up to keep it from chatternig if you continue to us a drill chuck. Delw |
| I have ER25 holder and collets, but none that hold .325 tool this is a custom tool, I can get the next batch made at .375 major diameter, same price, won't cause any problems and I got a 3/8 collet here's what my sub looks like, the drill tip is .306 long so the major diameter doesnt touch till the 2nd peck N1000 G0 Z.1 S7000 G1 Z-.3 F15. G0 Z.1 S3000 G0 Z-.28 G1 Z-.4 F7.5 G4 P.5 G0 Z.1 M99 |
| the 5/16 (will open)or 11/32 (will close) collet will work, these collets close nice and evenly, you won't need to order them if you have them, you will be real surprised at the results. I use them all the time and they are very accurate |
| ooops just saw the pause statement in your program, dump it(especially with a drill chuck) you can also get the same result if you just feed slower for the last .005 and wont notice a rise in part time. for some reseon a drill chuck when it doesnt have pressure on it will chatter like heck. if its one of those parts that has to have a pause I usually feed it slower like by half or less for .005. dont know why but its something I have done and it gives a nice finish. N1000 G0 Z.1 S7000 G1 Z-.3 F15. G0 Z.1 S3000 G0 Z-.28 G1 Z-.395 F7.5 G1 Z-.4 F2.0 G0 Z.1 M99 |
| Looking for small "blind hole"? clamps | rkremser | General Metalwork Discussion | 4 | 10-07-2008 07:23 PM |
| NEWBIE HELP>> How do you input a drill hole or extrude a hole that is.. | l u k e | Solidworks | 9 | 02-11-2008 11:54 AM |
| Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. | Geof | General Metalwork Discussion | 47 | 02-01-2008 02:32 PM |
| drill hole | larry53 | General Metalwork Discussion | 8 | 05-19-2006 07:50 PM |
| Drill hole | avengine | CNCzone Club House | 0 | 04-29-2006 08:33 PM |
