Old 12-04-2008, 06:04 AM
Ryehoon is on a distinguished road
Has anyone heard of tooling stone?
Hello everyone, this is my first post here, so I guess this is an intro in addition to my dilemma...
I'm right in the middle of machining an aluminum layup tool for an air duct on a plane, very large & awkward, and ALL 3D surfaces. so I left towers on the ends of my block, locating for the 2nd side is no problem, it's supporting the part to cut the towers off at the end that I'm going to have a problem with. A shop I used to work at we would use this orange-ish powder that you mix with water,into a 'mud', fill the cavity under your 3d part, and it would harden into a very rigid nest type fixture. Very handy! The owner called it tooling stone, but now that I need to find it, I can't get any results from anywhere by that name. Does anybody know what I'm talking about, and what it's proper name is? Thank you all, & sorry the post is so long
-Ryan-
Old 12-04-2008, 11:00 AM
dsage is on a distinguished road
Never heard of tooling stone but would plaster of paris work? Same process. Plaster of paris is runny though, so you'd need a box or something under the part to use as a mold until it hardens.
Sage
Old 12-04-2008, 08:02 PM
307startup is on a distinguished road
this is pretty similar...
check out this link:
http://www.acrtucson.com/products/Aquacore/index.htm
http://www.acmtucson.com/products/Aq...mium/index.htm
http://www.acmtucson.com/products/Aquapour/index.htm
http://www.acmtucson.com/products/Aquafill/index.htm
http://www.acmtucson.com/products/Aquaseal/index.htm
http://www.acmtucson.com/products/fastcore/index.htm
Old 12-05-2008, 08:59 AM
hkrok is on a distinguished road
Never heard of this, need study
http://www.roktools.com
Old 12-05-2008, 11:45 AM
Andre' B is on a distinguished road
This stuff is kind of an yellow/orange powder.
http://www.waterputty.com/
Old 12-05-2008, 12:41 PM
cdlenterprises is on a distinguished road
We use a substance called Rigidax for machining impeller blades. It very similar to a heavy duty wax. We simply heat it up, pour it into a mold and let it set. When your done, heat it up and melt it out. It's kind of messy to machine, but it sounds like it would work for what you're trying to do.
I don't know much about anything but I know a little about everything....
Old 12-08-2008, 04:29 AM
morgandeo is on a distinguished road
Re: Has anyone heard of tooling stone?
hi friend,
I have few information related to tooling is that from MAKO™ saw blades to polishing bricks and tool holders. Salem Stone is also the exclusive representative of Diamut diamond tooling for both CNC and manual applications. These innovative diamond tools are quickly becoming the industry “standard” for performance.
Anyone heard of this controller? noid Servo Motors and Drives 5 05-08-2009 11:44 AM
Ever Heard or seen one of these?? mgb1974 General Metal Working Machines 2 05-29-2008 07:31 AM
Has anyone ever had or heard of a......... Mac T. Knife Stepper Motors and Drives 6 03-18-2005 08:37 PM
Has anyone heard of cncxyz? noid DIY-CNC Router Table Machines 3 09-27-2004 07:20 PM
Has anyone heard this? brtlatjgt OneCNC 27 11-23-2003 10:00 PM
