Or in medieval terms 27/64". for standard 1/2" UNC 13tpi.BUT oops.. It may be smaller. What is with the regrind?
__________________ Super X3. 3600rpm. Two possible way to fix things: The right way or the other way. |
| Here is my bushman's method for calculating tap drill sizes. Find the decimal equivalent of 1/lead(pitch) in this case 1/13 = 0.0769" Subtract this from the OD; 0.5" - 0.0769" = 0.4231" Take the next fractional drill size up from this which is 7/16" = 0.4375" and you will get somewhere between a 65% and 75% thread; okay for most purposes. 0.4715" - 0.0769" = 0.3946" so you could choose between 25/64" or 13/32". But all this is not necessary; the tap was ground down by about 1/32" so simply go down 1/32" from the standard tap drill size.
Oops, misinterpreted by fast reading, I thought you meant 1/2" ground down. ![]() Anyway my bushmans method will work for 13tpi no matter what the diameter.
Some allowance, 0.015" to 0.02" on the diameter?
#10
| 1/2"-13 2B Pitch Diameter is pitch diameter of 0.450 to 0.4565, or an average of 0.45325 with a tap drill size of 0.4219 So if your pitch diameter is .4715 to .465, or an average of 0.46825, wouldn't it make sense to have a tap drill size of +.015" larger @ 0.4369"? |
| Tap & Drill Size | kiemkhach | General Metal Working Machines | 2 | 03-12-2008 12:54 PM |
| Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. | Geof | General Metalwork Discussion | 47 | 02-01-2008 02:32 PM |
| what size steppers for a mill drill? | CNC Darren | Benchtop Machines | 1 | 10-04-2005 12:36 PM |
| Size motors for Mill Drill | Runner4404spd | Benchtop Machines | 4 | 06-19-2005 02:09 AM |
| What size of drill bit can be used for 1/2-10 acme tap? | starCNC | DIY-CNC Router Table Machines | 11 | 04-29-2004 06:36 PM |
