  #13   Ban this user!
Old 11-30-2008, 12:36 PM
rfwyzard is on a distinguished road
Drilling oversize by the amout the tap is oversize is the solution. What material are you using? If it's soft like aluminum it's not as critical as if it's stainless steel or something even tougher. Also there's something called "First piece inspection". Self explanatory. With as many pieces as you are making you always allow for scrap.
Tap & Drill Size kiemkhach General Metal Working Machines 2 03-12-2008 11:54 AM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
what size steppers for a mill drill? CNC Darren Benchtop Machines 1 10-04-2005 11:36 AM
Size motors for Mill Drill Runner4404spd Benchtop Machines 4 06-19-2005 01:09 AM
What size of drill bit can be used for 1/2-10 acme tap? starCNC DIY-CNC Router Table Machines 11 04-29-2004 05:36 PM
