Old 11-21-2008, 04:41 PM
laka is on a distinguished road
Cleaning coolant stains from collets etc...
Has anyone ever had any luck removing the blackish coolant stains from their collets or milling tables?
Old 11-24-2008, 12:22 PM
JWB_Machining's Avatar
JWB_Machining is on a distinguished road
No Luck really Removing the stains, But after everything is coated in coolant and i wipe it all up as well as possible I spray everything with a Coat of LPS 1 and that has seemed to slow signs of any stains, and slows rust too. Don't know if that helps you but I'm interested to see if anyone has any solutions.
-JWB
--We Ain't Building Pianos (TCNJ Baja 2008)
Old 11-24-2008, 01:51 PM
If the coolant stain will not wash off with either acetone or methanol don't go any further because it is actually etched into the metal. This is particularly the case with the black stains that form under vises and things bolted to the table for a long time.
You could polish it off using Scotchbrite but in doing this you are removing metal and this is definitely not a good idea.
Coolant stains on aluminum JpBinc General Metalwork Discussion 14 11-19-2008 11:11 AM
Removing coolant stains from clothing? Cyre General Metalwork Discussion 7 03-18-2007 10:47 AM
Flushing/cleaning coolant reservoir? speedofsound Milltronics 0 10-25-2006 11:01 PM
Way stains Normal? Dan S Mini Lathe 1 09-27-2006 04:50 AM
Coolant/oil.... what about part cleaning? Any books? InspirationTool General Metalwork Discussion 4 08-16-2006 02:43 AM
