  #13
Old 11-26-2008, 11:51 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Also, for face milling a slight tilt to your tram (heavy on the leading edge) is the appropriate setup. Yes this will leave a concave surface, but it will be minuscule. This is done to keep the trailing edge of the cutter from picking out little gouges.
Light lubrication is required to keep the chips from welding. I typically will run the spout of the cutting oil can down the center of the cut once before starting. This is all that it takes.
www.integratedmechanical.ca
  #14   Ban this user!
Old 11-26-2008, 08:01 PM
HackMax is on a distinguished road
Thanks for the tips. I will have to see what i can do to tip the head a little. I guess a shim under the column would do it. Maybe my tramming isn't that precise (LOL) so that it does tip a little anyway. I'm still trying to salvage this first piece of AL. Seems I machined it with the backlash compensation deactivated. What a mess. I hope the next one goes better than this one. It is the first one I've done though so I guess I can write it off as R&D.
Rick
Rick
  #15   Ban this user!
Old 11-27-2008, 04:20 AM
TOTALLYRC is on a distinguished road
I will post pics this weekend, I can't seem to find the charger for the camera
Mike
  #16   Ban this user!
Old 11-27-2008, 08:40 PM
Mike
Thats OK mike anytime is fine.
Rick
  #17   Ban this user!
Old 11-28-2008, 07:58 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Originally Posted by HackMax View Post
I suppose I'll have to get some shim stock as well. Rick
Aluminum soda or beer cans provide excellent shim stock.
CR.
  #18   Ban this user!
Old 11-29-2008, 09:45 AM
CR.
Kewl CR I have plenty of dem beer cans around. Never thought of that. Thanks!
Rick
Face Milling Delrin Shane39 General Metalwork Discussion 6 11-07-2008 01:55 PM
face milling aluminum DerHammer General Metalwork Discussion 52 01-30-2008 11:20 PM
Help with face milling... peter.blais General Metalwork Discussion 18 09-24-2006 01:20 PM
Face Milling techniques & workholding advice needed. Moondog General Metalwork Discussion 7 11-10-2004 01:51 PM
VQC Face Milling three pass Ken_Shea Haas Mills 3 08-12-2003 11:10 PM
