#13
| I didn't see many dimensions there, but I've done some similar parts on a much smaller scale. I left the stock a bit longer. I tack welded the excess ends of 2 flat pieces of bar stock together and turned the OD on them, then cut the welds off or the excess ends to part them in 2 and then finish the details in custom aluminum jaws on the individual halves. Worked out very well with O-1 steel. Oops.....beat me to it, Now I see Langwadt's suggestion makes mine look redundant, but relevant. DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
#14
| Sometimes an imagination will carry you further than experience. I like the idea, would eliminate work holding issues. |
#15
I think no matter what way you make these pieces it will be overkill if all that is happening is they get driven under blacktop. I also do not see the idea of forcing them to splay out with a pipe will work as well in reality as it does in imagination. If I was making an anchor point to handle a working load of 15,000lbs I think I would want something a bit more elaborate than three pieces of metal 6" long (hopefully) splayed out under the blacktop with a bit of pipe.
#16
| That could work, because of it's size and the diameter I need I could only use 2 pieces (Obviously can't tell with dimensionaless pictures) but it's an option if what Feog says doesn't work.
__________________ -JWB --We Ain't Building Pianos (TCNJ Baja 2008) |
| How would I go about and make this? | freefall | ArtCam Pro | 8 | 07-11-2008 10:27 AM |
| Best Way To Make This? | DroopyPawn | General Metalwork Discussion | 8 | 12-15-2007 11:34 PM |
| trying to make a die. | Dougotio | Diemaking and Diecutting | 9 | 04-08-2006 05:37 PM |
| CNC able to make this? | kentrob11 | Hobby Discussion | 92 | 03-09-2006 08:30 AM |
| How can I make | cncman | General Electronics Discussion | 3 | 03-23-2004 01:49 PM |
