First you need to get a Knurling tool. Has 2 wheels with slanted (45 deg) raised edges for cutting. But it doesn't really cut it just presses into the metal and makes a Diamond pattern You have to match your speed and rev. so you end up with the Diamond raised areas. Look at the knurl with a loop and adjust as needed. You can get that info from the tool supplier.
LinkBack URL
About LinkBacks
