Old 11-16-2008, 12:41 PM
rathi_vk is on a distinguished road
Fanuc drilltape center model mate-t
hello,
1. One Fanuc make tapedrill center fitted with Fanuc 0ma system having seperate pulse coder for spindle not responding any m-code(command) All axes are running fine. When spindle command ie M03/M04/M05/M19/M29 etc is commanded, spindle start running but m-signal not getting finish and cycle start lamp remain on till the reset key is pressed. If it is possible post me input/output image list of the said machine.
2. Other machine make Makino mc65 fitted with Fanuc 15M system shows "B-axis harware limit" alarm and pallet, atc also not responding.
Backup Fanuc Tape Drill Mate Model T. GPena Fanuc 0 11-14-2008 12:42 PM
Need Help!- Help with Fanuc drill and tap center model T mmxmb Fanuc 1 11-10-2008 08:59 AM
Need Help!- Alarm 110 on Power Mate Model D/H AZDEN Fanuc 8 05-05-2008 09:09 AM
Problem- Power-Mate Model D iNUC Fanuc 1 04-19-2008 11:20 AM
Problem- Fanuc MATE-P-MODEL B Cole84 Fanuc 0 02-15-2008 12:29 PM
