  #13   Ban this user!
Old 11-16-2008, 12:37 PM
Numb Nut is on a distinguished road
Geof - thanks for the explanation - I think I understood some bits of it. I'm not sure I have the brains or motivation for learning physics or electrical theory!
Meanwhile, I hooked up the capacitor to the multimeter and it read 24.9 uF which is pretty darn close to the rated value of 25 uF so I guess it's working just fine.
Incidently, inside the junction box there are 4 wires going inside the motor, these are from v1, v2, w1 and w2 and all of these wires have low resistance with each other which I find odd - for some reason I was expecting to find 2 separate coils.
  #14   Ban this user!
Old 11-16-2008, 01:13 PM
If the electrical checks out try greasing the bearings, and look for rub marks on the rotor where it may have been touching the fields. When the bearings go sometimes there is enough slop that the rotor hits the field and it bounces around inside while it is running.
Physics is not that hard, at least at the introductory level and simple electrical theory can be very helpful when working with machinery; well worth the effort. It is also helpful to learn about forces and vectors and levers because this sort of thing comes in handy for moving machines and figuring out clamping on parts.
Old 11-16-2008, 01:21 PM
Al_The_Man's Avatar
According to my reasoning, the connections could conform to the start winding between W2 & W1 and the run winding between V1 and V2, this would reverse the start winding WRT the run winding when the straps were swapped.
In that case there should be a separation between windings when the straps are removed, if you get continuity between the two, this could indicate a short between windings.
  #16   Ban this user!
Old 11-16-2008, 02:39 PM
Kipper's Avatar
Kipper is on a distinguished road
Originally Posted by Numb Nut View Post
That diagram doesn't show the motor windings which are connected to the various points on the 6 terminals but you knew that, right?
The motor plate states that the capacitor is 25uF / 450V.
Anyway, it's time to get the capacitor out of the motor and hooked up to a multimeter in capacitance measuring mode. Oh yes. They always talk in the end...
Yeah....this numbnut just noticed the 6 posts and jumped to confusion
I had a "senior moment" possibly a "brainfart" or some such...
Keith
  #17   Ban this user!
Old 11-16-2008, 02:54 PM
Originally Posted by Kipper View Post
.....I had a "senior moment" possibly a "brainfart" or some such...
Senior moment????? Bl***y H*** you have to wait at least another 22 years before you can use that excuse.
EDIT: But you do live in a nice part of the country now the Dark and Satanic Mills are no longer in operation.
  #18   Ban this user!
Old 11-16-2008, 05:13 PM
Kipper's Avatar
It's been a while since you've been to Leeds Geof.....They started building skyscrapers here a year or so back......Bl**dy awful things! I rarely venture into the city centre....Nothing there except shops full of clothes gay bars and doorway urinals.....Not my kind of place.
I'll wait the 22 years before using the senior moment excuse...... I'll try "Transient intellectual block" for now
Keith
  #19   Ban this user!
Old 11-16-2008, 05:20 PM
First time was back in 1970 and it qualified as B awful then; most recent visit was 2004 but I just drove through. I spent four days there in 1996 attending a conference; it was much less B awful than 1970.
  #20   Ban this user!
Old 11-17-2008, 04:01 AM
I took the motor apart last night - absolutely no sign of damage - mechanical or electrical, nothing looked burnt or out of place.
As per Kipper's observation - there isn't a mechanical switch inside this motor.
I measured the wire resistances with the multimeter and with the terminal strips removed.
V1 - V2 = 8.8 Ohm
W1 - W2 = 8.8 Ohm
V1 - W1 = 6.3 Ohm
V2 - W2 = 8.9 Ohm
V1 - W2 = 7.5 Ohm
V2 - W1 = 7.7 Ohm
There's no discoloration of the windings which might indicate damaged windings - so it really does look that the windings are meant to be continuous like this.
Any more ideas?
Old 11-17-2008, 09:10 AM
Al_The_Man's Avatar
The start winding has to be separate from the run winding in order to reverse, they are usually connected internally only when it is built for one direction.
It would appear you have a short between windings.
  #22   Ban this user!
Old 11-18-2008, 06:00 PM
What you say makes perfect sense. The only thing is that it's hard to accept that the windings have gone faulty - the motor looks like new inside and out and hasn't had much use. I still haven't tried calling up the service and parts number but that's probably the next move.
ID:	69952   Click image for larger version
ID:	69953   Click image for larger version
ID:	69954   Click image for larger version
Old 11-18-2008, 06:17 PM
Al_The_Man's Avatar
It is possible that a short exists between windings and if the resultant current is not excessive you will not see any evidence in the windings.
If it is OK mechanically, Lets face it, there is not much left, after the capacitor is proved OK.
One thing to try is get hold of a clamp-on ammeter and test the current, also try it in the reverse direction.
VFD for a single Phase motor!! Yepez Servo Motors and Drives 4 08-10-2009 06:53 PM
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
30 hp spindle motor on 240 single phase? panaceabea Phase Converters and VFD 14 09-05-2008 05:29 PM
Need single phase motor help bob1112 General Electronics Discussion 8 02-24-2008 07:48 PM
Single phase IR motor with a VFD? in2steam Phase Converters and VFD 2 07-10-2007 11:23 AM
