Results 1 to 2 of 2
Thread: Good article on dual contact spindles/toolholders
    Registered Belding's Avatar
    Mar 2007
    http://www.moldmakingtechnology.com/...es/080303.html
    Just thought I'd share. I found it very informative.
    Registered Astonlee's Avatar
    Nov 2008
    United Kingdom
    This is well worth book marking!
    This is good article on dual contact spindles/toolholders, but I am a little surprised that they did not mention the BIG-Plus system?
    I have had experience of bell mouthing of spindle, when we first started fitting standard VMC like Bridgeports & Hurco’s with 10,000 rpm spindle.
    If they had been running all day at max-revs, we found if the operator did not remove holder overnight, or the program left the tool in the spindle. As the spindle cool the toolholder shank was rung into spindle. So when operator started up the machine, and wanted to carry tool change it damage the ATC trying to remove the tool, and the only way we could only remove tool safety was by running the machine for a few hours.
  1. Dual Z axis and Dual Spindle
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 08-28-2008, 04:15 PM
  2. Need Help!- CAT 40V AND CAT50V TOOLHOLDERS
    By CNC_BOB in forum General Metalwork Discussion
    Last Post: 06-18-2008, 08:13 AM
  3. Okuma toolholders
    By jas6142 in forum Okuma
    Last Post: 05-27-2008, 01:55 PM
  4. What is everybody using for toolholders?
    By Adamj12b in forum Benchtop Machines
    Last Post: 12-02-2007, 02:22 AM
  5. A good article on round bearings (bushings) versus square rail slides
    By guru_florida in forum Linear and Rotary Motion
    Last Post: 11-19-2007, 08:19 PM
