I am looking to make a kit of all the standard american and metric sized bolts. The reason being, I often reverse engineer parts and I need to look at a blind hole and try to figure out what thread pitch and size it is. Most holes are too small to get a thread guage into so I need to sit there and try threading bolt after bolt into the hole to figure out the correct size. Problem is, my bolts don't have the size labeled on them so I need to thread guage the bolts to get the correct size after I determine that it fits propery into the threaded hole. It would save me a bunch of time to get bolts that already have the size and thread pitch marked on the head. Thanks! |
| Ever try using taps? They usually are marked quite well. Dick Z ps If you're worried about damaging the existing thread, maybe you could use forming taps or thread $$$$$$$$$$$$$$ gauges.
__________________ DZASTR Last edited by RICHARD ZASTROW; 11-10-2008 at 05:02 PM. Reason: ps |
| If you "quite often reverse engineer..", I would think a set of plug gauges would be your best option. No, nobody marks their bolts, that would be very cost prohibitive. For a cheaper alternative, make your own plug gauges, simply a handle on a bolt with the size marked on it. Make a block, with sizes marked to store youur bolts....lotys of ways to do this.
__________________ I hate deburring..... Lets go (insert favorite hobby here) |
I would make handles out of aluminum hex, thread one side fine pitch, the other course, loctite studs and stamp the handle. For instance, 3/8"-16 on one side and 3/8"-24 on the other. |
This is a good way, and by "studs" I would use set screws.
| Ken
__________________ Kenneth Lerman 55 Main Street Newtown, CT 06470 |
#10
? When you say set screw, I think of the pic on the bottom. When I say stud, I mean the pic on the top? Anyway, another premade thread gauge pic attached, not precision, it's made for a turn-buckle type set-up. |
| X3 belt size/pitch | trcons | Benchtop Machines | 1 | 07-25-2008 10:40 PM |
| Nuts and Bolts - THREAD | High Seas | Hand Tooling | 0 | 04-17-2008 12:46 AM |
| help cutting 6 pitch thread | joe1970 | General Metalwork Discussion | 10 | 06-08-2006 09:43 PM |
| Size and pitch of leadscrews | transtar | Linear and Rotary Motion | 5 | 02-27-2006 11:13 PM |
| Ball screw size/pitch? | jakk100 | DIY-CNC Router Table Machines | 7 | 06-18-2003 11:21 AM |
