Old 11-10-2008, 08:28 AM
Mark18969 is on a distinguished road
Threading problem on Miyano
I have an older Miyano BNC34 lathe. It will not single point thread. This had worked in the past. At one time we lost the parameters on the machine and had to reinstall them. I do not know if this was the cause of the problem.
When we thread at a low RPM, the machine will follow the thread. Once we get to a higher RPM, after cutting 2-3 threads, it will seem to skip, and double cut the thread. We tried swapping the 2 servo drive boards with no change. We went out and replaced the spindle encoder, and that did not fix anything. That was an expensive swap. All that is left is the main board, and a possible parameter that we missed.
It's hard to get help from Miyano on this, and we are still chasing it.
Anyone out there have ideas?
Or if you have mid 1980 BNC34 and the parameters printed out, I would appreciate a copy so we can compare what we have to what you have.
Tags
miyane parameters
threading problem girishnadkarni Fanuc 6 08-29-2008 06:22 PM
Problem- CNC threading problem 3bmachine General Metalwork Discussion 5 05-25-2008 06:02 PM
Miyano T5V-25 problem. tac8357 Machine Problems, Solutions , Wireless DNC, serial port 1 02-01-2008 09:42 PM
Miyano parameter Problem AFX Fanuc 12 02-01-2007 02:28 AM
Problem with BNC Miyano Barfeeder lathe. Tonenc Machine Problems, Solutions , Wireless DNC, serial port 3 11-08-2005 08:46 PM
