Old 11-06-2008, 10:28 AM
JWB_Machining's Avatar
JWB_Machining is on a distinguished road
Milling 4130 Steel
I Just tried to mill this with a 1/2" Coated Carbide with the RPM at 400 and a Feed of 10 IPM with a depth of cut of 0.25" Instantly my Cutter Broke. This was with a SFM of 520 and IPT of .0025
The Machinery handbook tells me Run this at 100 SFM with .010 IPT which translates to RPM of 764 and a Feed of 15 IPM. Is this Right? I Only have one Endmill left and i've kinda gotta get this done today.
-JWB
--We Ain't Building Pianos (TCNJ Baja 2008)
Old 11-06-2008, 10:42 AM
400 rpm x 0.0025" per tooth x 2 teeth = 2IPM
If it was a four flute cutter it would be 4IPM
How did you get the figure of 10IPM?
Incidentally I think the Machinery's Handbook figure of 0.01" per tooth is a bit optimistic at least for a 1/2" dia cutter.
Old 11-06-2008, 10:44 AM
Sorry I Meant 4000 RPM. What's a Proper SFM and IPT when Milling Steel with a Carbide? Also how deep can my depth of Cut go before It Becomes a problem?
-JWB
Old 11-06-2008, 11:04 AM
For 4340 I would probably go with not more than 300 feet per minute, quite possibly less.
Feed per tooth on four flute or more, something like 1% of the cuttere diameter for cutters 5/8" and above and 0.5% for smaller than 5/8". Two flute cutters are not as strong.
Depth of cut around 1/4 of the cutter diameter, bit less for cutters smaller than 5/8", bit more for larger.
A point to remember is that SFM and feed figures given by cutter manufacturers and the handbook are sometimes predicated on a short(ish) tool life in favor of removing material fast; it is always a play-off between the cost of the tool and the cost of the time. For one-offs I tend to halve whatever is recommended because the extra time is normally a small proportion of the total job time. For production very often time is money and it is more economical overall to burn tools out faster.
Thread Milling Steel JWB_Machining General Metalwork Discussion 5 10-16-2008 05:13 PM
Milling a peice of steel dneisler General Metalwork Discussion 2 06-20-2008 02:44 PM
Turning 4130 steel? Pontiff51 General Material Machining Solutions 4 12-06-2007 10:20 PM
bending of steel after milling dhiruj General Metalwork Discussion 17 03-23-2007 02:29 PM
4130 Steel FAMOUSX1 General Material Machining Solutions 8 10-12-2006 11:16 AM
