Old 11-01-2008, 06:43 PM
nc9933 is on a distinguished road
a good plasma cutter for home
what is a good plasma cutter for home ,not the tiny ones but definitly small ones
and what is a good compressor for it that will also be good for general use...Are prices coming down these days cause of the downturn,???under a 1000 $ if possible
Old 11-01-2008, 07:03 PM
DSL PWR is on a distinguished road
I'd go with a Hypertherm 30 (1k), but if you could swing it go with a 1000(2k), as if you build a plasma table it makes life much easier with a machine torch. You should probably start with a 5 hp compressor.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 11-02-2008, 07:51 AM
USMCPOP is on a distinguished road
Hypertherm is good, as is Thermal Dynamics.
You will need to dry the air!
http://z6.invisionfree.com/ToolBoxTa...showtopic=1460
http://www.motorguardplasma.com/1plasma.html
Old 11-02-2008, 09:55 AM
does Therm recommend this drying air?? what is the cost for that 45 filter??
their site didnt say??
CNC Laser cutter versus CNC Plasma cutter? squale Laser Engraving & Cutting Machines 10 04-26-2009 04:59 PM
Plasma Cutter studysession CNC Plasma and Waterjet Machines 2 09-03-2007 09:23 AM
What is the best plasma cutter jpmassey CNC Plasma and Waterjet Machines 17 08-26-2007 01:15 PM
Good Foam Cutter CAM Software? vacpress General CAM Discussion 0 03-30-2004 05:26 PM
home made CNC wire cutter and router geesville DIY-CNC Router Table Machines 5 02-05-2004 08:24 PM
