I have a piece of 1/2" hardened steel rod from a printer carriage, and I want to drill and tap a hole on each end of it to mount it to a frame. I have an X2 mini mill and cheap drill press at my disposal. Are there any tricks to getting the hole centered on the end of the rod? Anything I should know? |
| I have a dial indicator and could center it in my mill -- if the piece wasn't 4 feet long. Sorry for not saying that earlier. It won't fit in my mill the with the end pointing up at the end mill. I'll check the hardness issue. |
| if you cannot drill and tap the rod itself, can you make some pinch clamps to mount the rod into and then mount eh pinch clamps where you need it? Or passably bore some holes where you want the bar mounted so that its a really tight press type fit? Press the bar into the bored holes with a tad bit of lock tight and it wont go anywhere. Just trying to figure out another method of skinning the cat..... with what you have..... |
| As far as centering the hole: Take a larger piece of material, say 1" square, and drill it through jus a bit smaller than tap drill. Then drill and ream it for a snug slip over shaft a good 1" to 1 1/2" deep. Slide it on the end of the shaft and run tap drill through into shaft. The longer you can make this slide on drill bushing the straighter it will keep you. As for hardness of the shaft, if it is case hardened, you have several options for that. If it is thru hardened....they're right it is edm time.
__________________ I hate deburring..... Lets go (insert favorite hobby here) |
#11
| one suggestion, if the material is really hard. Try heating up the ends to glowing red. Then allow it to air cool. This will soften the material to allow you to hopefully drill and tap it. EDIT If you go with the above suggestion with the drilling and boring into a block. Remember NOT to remove, or move the machine. (I know, hard to do) but this will help insure that you are in the center of the HOLE that was drilled and bored. |
#12
Huh? Not really sure what you mean by this, but I've actually done this with a hand drill. Of course doing it in a machine will be more precise.
| Hole drilling help | stevehuckss396 | General Metalwork Discussion | 23 | 01-27-2008 01:15 AM |
| Deep hole drilling | kalmah | General Metalwork Discussion | 8 | 09-09-2007 10:09 AM |
| Drilling a .010 hole | CoolhandLuke | General Metal Working Machines | 7 | 03-25-2007 10:44 PM |
| Drilling a hole in a 3D model | mayhugh1 | SprutCAM | 5 | 10-25-2006 11:51 AM |
| Deep hole drilling on OKK | eddie | G-Code Programing | 1 | 09-21-2005 06:55 PM |
