Old 10-30-2008, 02:03 PM
fhadk is on a distinguished road
CRS 1018 Tooling Help
Hi everyone.
I am having trouble getting a good finish when turning 1018. Part is 1.25" dia by 9.25" long. Turning down to .75 " 8.5" long. I am having slow way down to get a chatter free cut resulting in a crap finish.
I found a few threads related to my problem, and people said to use a positive insert. So my question is, do they mean an insert with a more positive chip break or a positive rake tool holder.
I am currently using a MCLNR with a CNMG431MP. This works great for 1018 when part is robust and can keep the speed up.Thanks for any advice/help you guys can muster.
Jesse
Old 10-31-2008, 12:16 AM
MFassler is on a distinguished road
thats cause cold roll sucks for finish! positive chip breaker!
Old 11-01-2008, 09:56 PM
g-codeguy is on a distinguished road
Use both. The two combined should let you increase RPM a bit. Go with a ground insert. Preferably a cermet. Hard to get a good finish with too slow of an RPM. Use oil if possible.
Old 11-02-2008, 12:06 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
It is likely because your part is expanding (thermal) and your tailstock is forcing it to orbit.
I find that it helps to leave the tailstock spindle unlocked and leave the pressure at absolute minimum.
What you are doing is PITA.
www.integratedmechanical.ca
Old 11-02-2008, 07:15 PM
I assumed a cnc lathe. Which type are you using?
Old 11-03-2008, 06:14 AM
It is a Haas SL-30. Thanks for the replys. I have some 12L14 coming today to get me through this part. I will definately be ordering some positive tooling though for the future.
Thanks again.
Jesse
Old 11-06-2008, 02:03 PM
MetalProBow is on a distinguished road
if you lookin for good finish when turning you could try using wiper inserts with a light chipload
Figuring Torque needed to tap a 1x8 thru 1018 doug9251 Mechanical Calculations/Engineering Design 1 08-05-2008 08:05 PM
RFQ: Turn / Mill work needed 2" dia 1018 dsmdude Employment Opportunity 6 09-27-2007 09:59 AM
1018 Round Stock in SE PA buckkillr8 Employment Opportunity 8 08-06-2007 02:55 PM
Drilling question 1018 and 4140 schiada96 General Metal Working Machines 3 11-27-2006 10:45 AM
Turning 1018 mjarus Mini Lathe 28 06-22-2006 09:46 PM
