Old 10-28-2008, 08:28 AM
JWB_Machining's Avatar
JWB_Machining is on a distinguished road
Machining Tantalum-Tungsten
Hey,
I have a .25" (Approx) piece of Tantalum (with 2.5% Arprox Tungsten). I need to face this down to 0.160. I am going to Use a 1" indexible end mill with Carbide inserts. And Recommendation on feeds and speeds and depth of cut? There's no info in the Machinery's handbook.
-JWB
--We Ain't Building Pianos (TCNJ Baja 2008)
Old 10-28-2008, 09:43 AM
djr76's Avatar
djr76 is on a distinguished road
found this, could use this as a starting point
http://www.hcstarck.com/index.php?page_id=354
Old 10-28-2008, 10:09 AM
Hey,
Thanks a lot I'll defaintely take that info into consideration. Odd though because Mastercam actually has Tantalum in it's materials library and it gives a SFM of 140, which is what I'm using right now along with a Feed per tooth or 0.0001 because this is what Mastercam gave me for another job. I'm also using a depth of .005 just to get a feel. Unfortunately I actually don't have any HSS end mills to use. I'll try these values out afterwards though and probably change my inserts. This material takes so long to machine.
-JWB
Old 08-30-2010, 11:57 AM
claya is on a distinguished road
tantalum
Have some questions on your tantalum experience. Sent a PM, but your PM box is full... Please empty..
ca
Old 08-30-2010, 02:12 PM
Cmailco's Avatar
Cmailco is on a distinguished road
What's the material condition? As long as it's not annealed, shouldn't be much of a problem. Use speed/feed data for Titanium, from whichever manufacturer you use for your cutter. Very highly positive cutting geometries seem to work best, moderate feed, lower speeds. 125-175 SFM, .004-.006 inch/tooth, keep the axial depths under .100, radial .2-.3D (peripheral milling) at the higher SFM range, .65-.7D radial (rough milling) at the lower range.
The Manufacturing Reliquary
http://cmailco.wordpress.com/
Problem- Threading 99.9% Tungsten Rod?!?!?! stuby General Metalwork Discussion 2 07-31-2008 10:15 PM
tungsten feeds and speeds question!?! dcrblazer General CNC (Mill and Lathe) Control Software (NC) 2 11-09-2007 03:35 PM
Tungsten Alloy??? stebanski General Metalwork Discussion 0 10-01-2007 04:17 PM
Tungsten-Copper Elkonite pqminc Composites, Exotic Metals etc 0 08-13-2007 06:38 PM
Chemical Tungsten sharpening zcases Welding, Brazing, Soldering, Sealing 3 12-11-2006 05:12 PM
